Hummer tires??
Discussion in 'The Garage' started by buffcc1, Dec 29, 2005.
  1. buffcc1
    buffcc1 Registered Member
    May 30, 2005
    42
    Wichita Falls Texas
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    I'd try and get wheels with the Goodyear MT's on them in a 37.... They are a radial and not a bias ply tire.
    Over on the PBB. "J20m715" is selling the MT's and wheels. He's in Garland, TX....
  3. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Well they ARE a bias ply mud tire. So yes they do flat spot and vibrate a bit. BUT, the bias style (8 bolt) rim used a magnesium beadlock/run flat that liked to "walk around a little inside the rim. The biggest joke was to try to balance these sonsabitches. A couple of miles and your balance job went out the window :doah: . The radial style (10 bolt) rim used a two piece rubber (now one piece) that doesn't move. So, theoretically, if you ditched the magnesium beadlock and used an aftermarket (PVC?) beadlock I wouldn't think they'd vibrate as much. NOTE: a rubber runflat/beadlock also became available for the Bias rim, but bias (mud) tires fell out of favor with most units.
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    My 36's are pretty decent on the road. i have a set unbalanced.:doah: they run better at 75 than 55...lol. they suck offroad though. save up and get a decent set or get th 37" radials
  5. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    You could look at govliquidation.com for them also. They always seem to have huge lots of wheels and tires for real cheap.
  6. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    If you don't plan on turning those wheels into beadlocks, I would suggest a set of H2 wheels and BFG AT take offs. They can be had for about $600 most places I have seen. 16.5 wheels are garbage if you want to air down. Plus the H2 wheels are bling 17"ers.
