Hummer tires
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by slider, Mar 22, 2006.
  1. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Anyone running Hummer tires? I have a chance to pickup a set cheap 36x12.50x16.5 Wrangler II's. How do they ride and wear? I know that they are Bias ply and probley will flatspot after sitting but I can live with that if they wear good. Thanks for the help. Slider
  2. Wishbone
    Wishbone 1/2 ton status
    Mar 6, 2006
    239
    Oklahoma
    surpip has a couple sets of those he runs.
  3. slider
    May 7, 2001
    547
    someone has to run these, sirpip anyone???????
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I have had a few sets. got them for free so I can't complian too much.
    They will flat spot but not that bad even after sitting for a few weeks. It goes away within a few miles.
    The tread life seems to be pretty short lived, even when properly inflated.
    Offroad, they are not the greatest tires but they do work.
  5. eclipse
    eclipse 1/2 ton status
    Jan 1, 2005
    1,245
    Sparks, NV
    only if they are dirt cheap, I have an old set on my 77 and I dont like them.
  6. G-Force8
    G-Force8 1/2 ton status
    May 15, 2005
    476
    DFW, Texas
    Hummvee take offs are always cheap. I have picked up (8) of them and (4) 8-bolt beadlock hummvee rims w/runflats lately and I only have $250 in the lot.
    They are workable, and much better than a typical all-terrain. For me, I bought them to run while I do other mods and save up for Swampers.
    They're a go-between tire. Cheap, and will get decent traction. It sounds like you just want to spend as little as you can to get something that will work.....and this tire is it.
  7. grizzlyoffroad
    grizzlyoffroad 1/2 ton status
    Mar 31, 2006
    100
    Soldotna, Alaska
    I ran these tires for about a year. They were OK, decent traction, not too rough, not to loud. There are a good transition tire. If you live in a cold climate, they get real hard in freezing temps and become very slick. Not good on ice at all. I guess it just depends on your uses.
  8. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    how about the 37" humvee tires? those seem better looking
  9. grizzlyoffroad
    Mar 31, 2006
    100
    Soldotna, Alaska
    Sorry for the confusion, those ARE the tires that I ran, the 37" ones...even though they really aren't much taller than a 35. After the 37s, I switched to the 38" Dirt Grips and they seemed huge in comparison.
