Hummer Wheel Parts
Discussion in 'The Garage' started by nvrenuf, Dec 27, 2004.
  1. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    Any members here sell parts for Hummer wheels? I need o-rings, valve stems (different?) and maybe a couple of studs & nuts - just small parts.
    I know USA6x6 is the standard answer but with all of the negative feedback I'm uneasy about dealing with them.
  2. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    Have you tried Stazworks?
  3. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    No, he does parts? I knew he sold the pvc inserts and stuff but I hadn't thought about him for the little stuff.
  4. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    I bought my o-rings off usa6x6....didn't have a problem contrary to what most say.
    Oh, I think I just stirred the pot. This post will now grow to 3 pages long.
  5. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Sapper just bought a set of centers for his hummer rims from USA 6x6 and had no problems. As far as parts let me know exactly what you need and I will look around at work and see what I have.
    James
  6. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    SAWEEET!
    I've (5) 8 bolt style surplus wheels, the only thing I'm sure I need is o-rings and valve stems (if they're different, can you find out?). I think the studs & nuts are all ok, I was just going to get a few for spares.
    These wheels have that hard black or green paint/coating, any suggestions for stripping it off? I hit them with oven cleaner and a pressure washer but they just laughed at me. :doah:
  7. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    That paint is most likely CARC. I would reccomend that you just paint over it. If you really want to remove it then you should first do a Google search for CARC, and see what you are getting into.
    At a minimum you will need a respirator
  8. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Valve stems are the same as any other wheel, best thing to strip off that paint would be sandblasting, that CARC paint is TOUGH.
  9. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    GREAT! Thanks for the valve stem info!
    I searched for theCARC stuff and it sounds nasty. :yikes: I've always had good luck using oven cleaner as a stripper/cleaner but it didn't budge this stuff. :eek1:
  10. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Yep sand blasting would be the thing to do to get the CARC off. I just CARC painted my truck. I love it. I will look around tomorrow and see what I can scrounge up as far as O rings and a few extra studs and nuts.
  11. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    Bought all my parts thru GM. Not very pricey and right the first time.
  12. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    hey man, i got my h1 wheel parts from, marion humvee in atlanta. they got a parts guy there that is super h1 smart. i got the number at the house if u want i can get it for u tommorrow.
  13. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    Yeah, please! I called my local (new) dealer here and the guy didn't have a clue about what o-rings I wanted. :surepal:
    THANKS!!
  14. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    The Valve stems are not the same. At least on my 12 bolt wheels they weren't. Only difference is that the lots for them are rectangular instead of round. All you need to do is drill it out to fit your standard steel stems or rubber ones. I used the steel stems once I drilled them out and it has been fine for a couple of years.
    I also bought some o-rings from USA6X6. They shipped them out immediatly. Only problem was that they sent me 8 bolt o-rings instead of 12 bolt. But I was still able to make them work.:crazy:
  15. BlueBlazer
    Feb 15, 2001
    1,940
    His post said he has 8 bolt rims, that is what I have in my garage, they use standard valve stems and have held air for almost a year with no leak, I would say there is nothing special about them.
  16. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    John,
    Didn't have any around my shop but after the first of the year I will pay a visit to a buddy who works over in the Tire Changing Facility and snatch you up some O rings and some spare studs and nuts. I think he gets back around the 5th or so.
    James
  17. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    I'm in no hurry so that sounds GREAT!! THANKS!!:waytogo:
