Hummer wheels on a K-30 drw
Discussion in 'The Garage' started by Ronnie4wd, Feb 18, 2003.
  1. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
    Would it fit right on the Dana 60 front.And could you put it inside out and single on the 14 bolt dually rear /forums/images/graemlins/crazy.gif
  2. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    On the front it would fit fine. You could do it on the rear backwards, but the wheel will have to be ....(thinking of right word.....) *modified* to allow the lug nuts to seat. It's not exactly square, but will fit, or you can do this on the back...
  3. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    To clearify:the 14 bolt is not the wide one or the hubs on it arent.
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We'll be using a fleetside D70 dually rear with SRW 14 bolt hubs. Same overall width as a dually 60 front.
  5. Kyle89K5
    2,273
    OKLAHOMA
    I didn't know those hubs were interchangeable?!?! Bolt on deal?
  6. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    I think I've got the backward rim on rear thing figured out. Normally the DRW trucks use a flange between the rim & lug nuts because the rims arn't tapered at the seat. If you use one of these rings on the back side of the the insideout rim on the rear you will once again have a tapered seat. Just use the correct lug nuts. This is still theory untill the spring when I put my junk together.
  7. Kyle89K5
    2,273
    OKLAHOMA
    Makes sense though. There's a guy in TN running (or was) this way with a D70 in the back and a Dually 60 in the front. Worked good, just looked a little funny /forums/images/graemlins/laugh.gif
  8. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    Thank you guys.Sure going to try it soon as I get a hold of some Hummer wheels (not so easy in this part of the world). /forums/images/graemlins/thumb.gif
