Hummer wheels
Discussion in 'The Garage' started by tomseviltwin, Mar 22, 2003.
  1. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    I found someone with a pallet of hummer biased ply style (16.5")beadlocks without runflats for $25 each. What would it cost to fis these for my truck? Is that a good deal?
  2. One_Ton_k5
    One_Ton_k5 1/2 ton status
    Jan 30, 2003
    168
    St Paul Minnesota USA
    yep, buy them all.
  3. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    i know some guys doing the hummers right now
    you need to cut the centers out and buy new centers(around $50.00 each) to get the back spacing you need. then you need to have them welded in place
    so the cost of removing the centers, cost of new centers and welding them in...would run around $75.00 to $125.00 per rim
  4. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i thought hummer wheels were so good was because they were two piece wheels that you could take apart easily. /forums/images/graemlins/confused.gif
  5. TONYP
    Aug 13, 2002
    2,116
    so cal
    you can, but the backspacing will not work for are trucks, some have the mounting center ring on the outside ring and some have it on the inside ring /forums/images/graemlins/k5.gif
  6. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
  7. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Running a Dually D60 front end and Hummer beadlocks. Fits up just nice. The 7" of backspacing really is a killer.
  8. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Good because the outer piece acts as a beadlock. Not good 'cause they are hard to balance and backspacing issues.
  9. tomseviltwin
    Dec 23, 2001
    2,065
    Utah
    How big are your rear spacers?
  10. fr8train
    Aug 2, 2000
    1,712
    Maryland
  11. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Notice this part: [ QUOTE ]
    without runflats
    [/ QUOTE ] That makes them NOT beadlocks as the design needs the runflats in order to lock the beads. Some people cut the runflat rib off and just use the beadlock part, but to do that you need to start with all of it.
  12. tomseviltwin
    Dec 23, 2001
    2,065
    Utah
    Notice this part:
    Quote:
    without runflats
    yes, but that's why you do this.
  13. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    PVC huh ? No thanks.
