Humming noise coming from a 208
Discussion in 'The Garage' started by RAY, Nov 16, 2004.
  1. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    When I am driving I am hearing a humming noise that I think is coming from the transfer case. The noise is constant whether I shift into neutral or a different gear. I pulled the fill plug and the fluid came pouring out like it was way over filled. Isn't there suppose to be a gasket between the tranny and T case? Anyone else have a similar problem like this?
    Thanks,
    Ray
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i bet your tranny fluid is low now, there is a seal in the tcase to keep the fluid seperate. pull the tcase and replace the seal.
  3. RAY
    Jul 4, 2000
    281
    Austin, Texas
    I pulled the transfer case and fixed the seal problem, but I still have the humming noise. Also, the pitch of the noise changes as my speed changes. Anyone have any idea what this could be?
    Thanks,
    Ray
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    possibly a bearing going out, just have to find out where
  5. BURBicon
    BURBicon Registered Member
    Dec 11, 2004
    78
    Sunny Phoenix
    Re: Humming 208
    I bet its humming because it doesn't know the words. Did you check your Ujoints?
