humming noise
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FatBoyBlazer, Sep 8, 2001.
  1. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    i've got a humming noise that i think comes from the front end........not sure what it is thought.....it kind of sounds like a bunch of crickets........what could be wrong
    high
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Three ideas off the top of my head - power steering, u-joint, or water pump.
    1 tequila 2 tequila 3 tequila Floor
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    it's only when imove though.....
    high
  4. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    In that case, check all of your u-joints, brakes and wheel bearings.
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    It could be the wear indicators on the front brake pads. They can chirp like crazy when its time for new pads.
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze>http://coloradok5.com/gallery/Thunders-Blaze</a>
    <font color=orange>Charter Member of The Too Much Fun Club</font color=orange>
  6. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    A litle more info here would be good[​IMG]. When does it happen? Moving? turning? stopping? accelerating? Maybe it is Crickets!!![​IMG][​IMG]
    <font color=blue>Esteban</font color=blue>
    <font color=red></font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/Estebans-album>Take A Gander At My Truck Here.</a>
  7. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    if its while moving from the front end its probably your wheel bearings...just repacked mine this week...try jacking up one side grab the tire and try to move it in and out....shouldnt move much...if you have big tires take them off then grab the rotor and try to move it in and out...if it moves accessively repack asap.....be sure to check both sides
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
    1982 Chevy C-10 Longbed
  8. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    just fixed it....it was the complemens of a cracked lift block....my axle was side ways and the ujoints were smacking together
    high
  9. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    lift block on the front!!!!!!! Did I read that right? As far as I know they are illegal in every state in the us. they are very unsafe cuz they can't handle the weight of the front end and that is why it broke!!!!!!
  10. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    nope i got the blocks in the back i meant the uv joints
    high
  11. hammer
    Aug 29, 2001
    449
    Binghamton N.Y.
    ok. you only said in the original post the front. then you said the lift block. you didn't specify
