Humming t case ?
Discussion in 'The Garage' started by Chrisblazzer89, Nov 12, 2006.
  1. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    my t case is huuming in 4lo does that mean it needs new fluid if so what kind and how do i replace it?
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    Your going to have to be a little more specific. What T-case do you have?
  3. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Either a NP208 or a NP241 dont know but its a stock for an 88 blazer
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    standard trans fluid, drain plug you unscrew at the borrom facing the rear, fill is on the same side towards the middle/top.
    check the level with the top hole,
    just so you know, mine whines some as well, i figure it's just the gear reduction going on in there, especially when you get to rollin at alittle higher speed than it really wants to:p:
    similar to the whine that happens in a standard trans vehicle when in reverse.
  5. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    yea thats the noise it makes. Just like u said wen i go faster it gets louder
    btw thanks for the help i will drain and refill tommrow
  6. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    every truck with a 208/ 241 had made this noise, as far as i know its perfectly normal...
  7. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    That noise means it is a 208:haha:
  8. KGsK5
    KGsK5 1/2 ton status
    Aug 26, 2006
    343
    Havre de Grace, Maryland
    my 208 makes no noise at all :D :p:
