Humvee axles
Discussion in 'The Garage' started by DieselBurb, Jun 22, 2005.
  1. DieselBurb
    DieselBurb 1/2 ton status
    Oct 8, 2002
    201
    Mt. Vernon, Missouri
    After the not-so-warm response from another site, I'll ask it here. Does anyone know how makes the axles for the Humvee's?
  2. dremu
    Feb 27, 2000
    15,961
    452
    East of San Francisco
    Uhh ... note that the M998 family has independent suspension front AND rear, so they're more like half shafts or CV's than the regular straight axles.
    You can get them at your local parts place.
    Or do you mean the portal gear boxes on the ends?
    -- A
  3. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    the center mounted differentials use AMC model 20 internals the shafts and geared hubs are unique to the HMMWV
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I know there are several types of cv shafts but I've heard one of them is the same as a ford taurus.
  5. SUB-ZERO
    SUB-ZERO 1/2 ton status
    Oct 8, 2002
    219
    Virginia Beach,Va.
    Ford parts in a GM?Blasphemy!!That can't be right...I thought they were supposed to be strong.
  6. DieselBurb
    Oct 8, 2002
    201
    I'm looking to find out who make the differential as in so that I can find out if they make something in the class 8 truck realm.
  7. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Those cv's would be stronger in the hummer because of the portal hubs gear reduction.
  8. dremu
    Feb 27, 2000
    15,961
    452
    :haha:
    The diff is, as mentioned, an AMC 20 ... basic light-duty Jeep stuff. It can get away with it 'cuz there's a 2:1 gear reduction at the hubs.
    Methinks you're barking up the wrong tree if you're after heavy duty drivetrain stuff -- look to Rockwell axles, f'rinstance.
    -- A
