hurculiner pictures
Discussion in 'Pacific Region' started by k5blazerus, Jul 19, 2002.
  1. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
  2. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    linky no worky...
    J
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    now it works /forums/images/icons/smile.gif looking good /forums/images/icons/smile.gif
  5. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    AWSOME DOOD
    How difficult was teh prep work????
  6. reddog64
    Nov 9, 2000
    3,325
    it looks like you wore through it on the frivers side floor???? /forums/images/icons/shocked.gif /forums/images/icons/shocked.gif /forums/images/icons/shocked.gif /forums/images/icons/shocked.gif
    did you ? /forums/images/icons/mad.gif
  7. k5blazerus
    Apr 22, 2001
    654
    Bend, OR
    No its not wore through its just dirt. I dont think it will for a long time. I caked the stuff on there pretty thick.
    The prep work was not so bad on the lower part of the truck that went smooth. The inside sucked and it took awhile to clean all the dirt out of the cab and to do the final prep work on it but it was worth it. so far so good.
    Colin
  8. reddog64
    Nov 9, 2000
    3,325
    about the prep work...
    what steps did you take to prep the areas to be covered.. what did you use to rough the surface till it's dull or did you go to metal or what?
    I'm gonna be doing htis very soon!!!
  9. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yeah me too...was there any sanding or scuffing that had to be done first for this stuff to stick. How thick did you put it on?
  10. k5blazerus
    Apr 22, 2001
    654
    Bend, OR
    Well I basically just ruffed it up with 80 grit sand paper . Then I sprayed the cab out with water let it dry and then I took a scotch brite pad with some High quility dirt,wax,grease cleaner and ruffed it up some more then I let it dry. then I made shure it was dirt free and I started to hurculiner it. ITs pretty strait forward. I did 3 layers thick and It pretty thick and it dose not event need to be that thick But I just did it for the hell of it. .
    Colin
