HVAC adjustment or ...
Discussion in 'The Garage' started by Wingnutt, Dec 16, 2005.
  1. Wingnutt
    Wingnutt 1/2 ton status
    Feb 20, 2000
    324
    NOVA
    should there be a bit of warm air coming out of the dash vents when the heater is on? I replaced that d*mn plastic "arm" that controls the blend door, but no matter how I adjust the arm outside the heater box wher I *think* it should be, I still get a fair amount of air flow out of the dash vents. With the defroster on, I get very little hot air out of the deforost vents, more is actually more air coming out of the dash vents! If I adjust the control arm so that I get a decent flow out of the defroster vents, when I set the control to vent, things get into a bind and the control arm slips in it's holder. If I move the adjuster arm where nothing is binding, the blend door is open about 1/2" allowing the air to flow out the dash vents. Needless to say, this is driving me nuts!:mad:
    Does anybody have any suggestions, or am I missing and adjustment somewhere? TIA
  2. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    I have the same problem on my 90.
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    The foam seals on the doors inside are infamous for rotting and not sealing in any position. Your rigs *seem* to new for this,but you never know.
  4. Wingnutt
    Feb 20, 2000
    324
    NOVA
    Anybody else?
  5. outsider223
    outsider223 1/2 ton status
    Mar 17, 2002
    122
    Green Bay, WI
    I have the same issue on my 90. Seems no matter what setting the controls are at, most of the air comes out the vents. Any help?
  6. xpoc
    xpoc Newbie
    Nov 2, 2005
    Minot, ND
    When I first got my 89 I had this problem I took off the dash finding that all the platic tabs holding the ducking together had broken. So I glued everything back together ziptied the flex elbows on and reinstalled everything it improved it signifigantly.
    also check for holes in the ducting
    gl
  7. Wingnutt
    Feb 20, 2000
    324
    NOVA
    One more bump for some additional ideas. TIA
