Hy-steer ???
Discussion in 'OffRoad Design' started by UNCLE CRACKER, Nov 13, 2002.
  1. UNCLE CRACKER
    UNCLE CRACKER 1/2 ton status
    Dec 29, 2001
    937
    PORTLAND OR
    Hey Steve are you guy going to make hy-steer arms? I am wanting to go with a hy-steer set up and I was very pleased with the quality of your dana 60 cross over steering arm. so I was wondering if you guys had somthing ready to go.
  2. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Same question. I've been impressed with OffRoad Design so far but have been looking at the Avalanche Engineering high steer setup too when I do my crossover steering. Seems that the prices are in the same ballpark. But, how strong are those heim joints compared to tie rod ends? Steve?
  3. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Ok, found some comments in another post about the major stress put on the rods by using a high steer setup so you may have already answered the question. I wonder how many folks have gone with a high steer and have broken stuff as a result.
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I know of at least one with a couple broken parts!
    We have looked at a couple of alternate ways to do this and nothing works out as well as I'd like. We may go ahead and build a 2 hole right arm and just sell it with a disclaimer and a really beefy tie rod. I don't think it's going to be a good street setup ever but for a trail rig it may be worth the tradeoff.
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> How about a behind-the-knuckle setup? </font color>
  6. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Haven't broken mine yet. I have the Sunray Engineering arms. Lord knows if it could be broke, I would break it. /forums/images/graemlins/crazy.gif
  7. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    I 2nd THAT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  8. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    could you post a link to that thread...i am not understanding how it would but alot more stress on it /forums/images/graemlins/confused.gif..
  9. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Have you considered the heim joints Steve? Or are the stock style tie rod ends that much more beefy?
  10. jstevenj
    jstevenj Registered Member
    Aug 28, 2002
    94
    north Miss.
    Re: Hy-steer ??? *DELETED*
    Post deleted by Stephen
  11. blk87K5
    Dec 26, 2001
    1,290
    Lubbock, Texas
    I wouldn't make it a habit either. /forums/images/graemlins/wink.gif Buy a membership if you want to sell something. /forums/images/graemlins/thumb.gif
  12. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    Please remove this post. like stated before, pay the 25 dollars or use PM to let people know you have stuff for sale.
    Grant
  13. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Obviously judging by the number of people making the tie rod over setup work, it can work. What you have problems with is there is less margin for error. As Mr Fox has proven, the tie rod sees a lot of stress and if it's not all done just right, it fails. Also, with the rod moved back you have a much greater chance of having a shimmy or "death wobble" problem. We do have one customer that put the rod in the factory location just because of this. I'd like to find an ideal solution but I'm really not sure there is one so we're looking at just optimizing what we can and making sure the customer knows there may be some problems.
    We have looked at double ended arms to put the tie rod behind and it is once again a situation where it may work for you but isn't really something we can sell as a bolt on kit. Then again, all a lot of guys need is a place to start.....
  14. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    I went hysteer and built a tierod out of 2" solid 4130 rod
    and used 3/4 heims and havent even come close to breaking anything.I agree that if you go hysteer and dont beef stuff up it will eventually fail.........
  15. UNCLE CRACKER
    Dec 29, 2001
    937
    PORTLAND OR
    do you have hydro assist?
  16. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Stephen,
    I ordered my D60 arm with intentions of going Hi-Steer some day. On the phone, you had mentioned the possibility of making the arm for the left side with single hole and then running a tierod with hole for draglink tierod similar to yours. Is this still a possibility? What are the pros - cons of this setup?
  17. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I think a solid 2" chromo bar will handle whatever you can do to it! I'm running a 1.5 x .188 wall DOM tube with no problems! It's typically stuff like small shank rod ends that hurt you in regard to strength. The amount of slack you can get in the ends is more critical when the tie rod is moved back, that's what will cause or increase the "death wobble".
    Problems with running the draglink into the tie-rod:
    Complex tie rod (compared to a simple tube anyway)
    shorter draglink
    tie rod will roll up and down when you steer which takes away a little of your steering motion and gives it a slightly less responsive feel.
    Pros:
    Downhill draglink end pivots, does not need or use much angularity.
    Lets you keep the tie rod mounted farther out
    Arms are less complex since they only have/need one hole
  18. mudddog91
    Dec 28, 2000
    471
    north carolina
    Yep ive got hydr assist.
