Hybrid doubler
Discussion in 'OffRoad Design' started by DougP, Dec 2, 2002.
  1. DougP
    DougP Registered Member
    Jan 15, 2001
    17
    Sonoma County, CA
    Thanks to my very first eBay bid, I'm soon to be the owner of a '79 F-150. Now I can start the axle swap project on my '95 Dakota.
    Drivetrain will be:
    Dodge 5.9l Magnum engine, Dodge NV4500, Doubler(Dodge NP203 & Ford NP205,) Ford Dana44 Front, Ford 9" rear.
    So how long does it take for a custom Doubler?
    How much $$$?
    DougP
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    You don't need a custom doubler. The standard ford doubler should work fine for you. I am pretty sure I am right in saying the range box on the 203 were the same so the ford doubler should bolt right up.
    Mike
  3. Stephen
    Sep 15, 2000
    4,228
    144
    Carbondale Colorado
    Hybrids are $760 and lead time is about 2 weeks max. We run alum. about every 2 weeks so it might come out the next day or it could be the full 2 weeks.
    You probably won't need a dodge/ford, the dodge and GM 203 bolt patterns are the same so if you get a GM/Ford adapter and drill your 203 face to match our mounting foot angle, you'll have it. The ford 203 bolt pattern is different from GM and dodge.
