hybrid joint?
Discussion in 'The Garage' started by TXsizeK5, Feb 20, 2003.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Where can I get a hyrbid joint to connect my shaft with the new 14bolt im throwin in? What are the "numbers" for the two diff ujoints again? Does ORD, Echobit, or A-tron or Offcamber 4x4 sell this hybrid joint?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The joint I used was Napa #447.
    It is a 1310-1350 hybrid I believe.
  3. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    hoss was correct it is a 1310 1350 joint.it is neapco part number 3-3140.that would be the number to cross refference at the parts stores.
  4. 77 Mud Buddy
    77 Mud Buddy 1/2 ton status
    Oct 31, 2002
    228
    Austin, TX
    I fellow K5 guy and I bought the Napa p/n 447 u-joints for our 1/2 ton ( 1310 ) yoke drive shaft to one ton ( 1350 ) yoke rear axle swap /forums/images/graemlins/grin.gif.... They didnt work /forums/images/graemlins/angryfire.gif. The 447 joint caps measure in at 1.18" on the (1350) one ton side and 1.125" on the (1310) 1/2 ton side. THE ( 1310 ) 1/2 TON SIDE DID NOT FIT /forums/images/graemlins/confused.gif. I later measured my 1310 yoke at 1.065" and my 1350 yoke at 1.18"
    I called NAPA and found the part number I needed for the size I measured. From what I know now I need either part number 348 ($27.50) or 448 ($26.50). The difference between the two I do not know yet /forums/images/graemlins/confused.gif, I am thinking greasable or non-greasable. Both of these u-joint caps measure correctly at 1.18" x 1.063" and are outer type caps. I will know soon if these work or not but what I do know is the 447's did not work for me or my fiend in our application /forums/images/graemlins/frown.gif.
    /forums/images/graemlins/deal.gifI have a 77 K5 which had a 12 bolt and I am putting in a 14 bolt FF in from a 73 3/4 ton truck.
    /forums/images/graemlins/deal.gifMy friend has an 83 K5 which has a 10 bolt and he is installing a 2000 14 bolt SF. ( I think his info is right )
    Hope this helps somebody ! /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  5. 77 Mud Buddy
    Oct 31, 2002
    228
    Austin, TX
    it looks like the difference in the 348 and 448 are the width of the 1.063 caps ( 1/2 ton / 1310 ). One is wider than the other but I dont know which one is for my application... Need to do a little more research!
    /forums/images/graemlins/pimp1.gif
  6. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Here's my understanding:
    The Napa PN 447 is a 1330-1350 combo joint used in going from a 10 bolt to a 14 bolt.
    The Napa PN 348 is a 1310-1350 combo joint used when going from 12 bolt to 14 bolt.
    The 1330 and 1310 use the same size caps, but the width of the joint is different. The 1310 joint (the 12 bolt joint) is smaller in width than the 1330 (10 bolt joint).
  7. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    Funny thing is when I installed my 14ff (1973) in to my 88 Jimmy with 10 bolts, I was able to use the original stock u-joint, what's up with that?
  8. heavy4x4
    Aug 28, 2002
    3,270
    Someone before you must have swapped the 14 bolt FF yoke out to a 1330 /forums/images/graemlins/crazy.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/thumb.gif
