Hybroboost brake swap and anti locks
Discussion in 'The Garage' started by hidesertwheelin, Feb 16, 2007.
  1. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    My 90 bub has anti-lock brakes on it. The sensor is on the transfercase. My question is will swapping to a hydroboost affect the anti-locks? i don't really care if they don't work, I just don't want my brake idiot light ot be on all the time. Also do I just throw away all the proportioning valves that are below the master cylinder (I think they are for the anti-locks).
  2. hidesertwheelin
    Nov 13, 2004
    782
    4
    Hesperia, CA
  3. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    I originally swapped to hydroboost and kept the anti-lock brakes on my '90 blazer. Yes the proportioning valve under the master cylinder is what the ABS works through. If you get rid of that you will have to get another proportioning valve...like one from the truck you are takinng the hydroboost from (which will be located up on the front frame crossmember)
    I kept my ABS to see if it would help with rear-lockup people experience when they switch to discs on the 14 bolt. I never got that far before I trashed my blazer frame and *had* to buy a K30 :whistle: so I now longer have ABS. Good luck!
    EDIT: And to answer your question: No, switching to hydropboost will not negatively affect the ABS...I did panic stop tests to verify this :D
