Hyde. clutch rebuild kit?
Discussion in 'The Garage' started by dyeager535, Apr 9, 2004.
  1. dyeager535
    26,979
    Anyone know someone that carries them? Let the neighbor check the clutch pedal feel on my truck. It was pretty stiff, since the slave cylinder was fully extended and it was just hanging from the truck.
    Word of advice, don't push on the clutch pedal with the slave cylinder bled and unbolted from the bellhousing. /forums/images/graemlins/smile.gif
    Anyways, he broke the pushrod on it (snapped in half pretty easily lol) and I have a spare. I noticed this "new" aftermarket piece that broke was leaking into the cab anyways, so I figure I'll take one of the used GM pieces I have lying around, and rebuild the one I have. IF I can find someplace that carries a rebuild kit.
    No luck at napaonline.com.
  2. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    run google search.. I just looked at them last night... sorry I didnt save the link
  3. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    LMC carries them.
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    OEM is Girling unit
    the Raybestos replacement junk is aluminum and I am uncertain if their kit will fit the OEM Girling
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Are you sure?
    I've never heard of a Girling part stock on an American car.
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    well it is from memory of the OEM literature when I bought my OEM parts twice now
    it stuck as I thought it was very odd as well
  7. dyeager535
    26,979
    Well, gmpartsdirect doesn't list or stock the OEM rebuild kit or master cylinder, based on the numbers in my parts manual.
    Found some reference to girling stuff online, but can't tell (quickly) where they are even located. Probably share common bore diameter with other products, but doesn't seem to be much in the way of Girling info online.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If you can find a part number, I can see what I can do. I know how to get Girling.
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    GM PART # 15615868
    CATEGORY: Clutch Slave Cylinder/Actuator
    PACK QTY: 1 CORE CHARGE: $0.00
    GM LIST: $112.89
    OUR PRICE: $64.35
    GM PART # 15615867
    CATEGORY: All
    GM LIST: $115.74
    OUR PRICE: $65.97
  10. dyeager535
    26,979
    Well, definitely different numbers than the ones in my manual. Probably just changed the part number.
    Whats what in your list? Not a bad price if the first one is the whole cylinder, but pretty expensive if either of those is just a rebuild kit!
  11. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
  12. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    those are the cylinders pricing quoted from gmpartsdirect to show you the new part numbers
    if you get rebuild kits let me know the part numbers and pricing
    I need/want them as well
    if you find a deal where buying 1/2 dozen gets a deal I will go in on it
