hydraboost PS pump
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigJohnson, Jan 2, 2003.
  1. BigJohnson
    BigJohnson 1/2 ton status
    Jan 22, 2001
    207
    AL
    I got a power steering pump for diesel truck without AC because it had two returns and a normal resivor. I am trying to mount it on a 350 with 350 brackets and it dosen't fit. I seems the pump itself is rotated about 45 degrees in the resivor. Can I turn it back 45 to make the bracket fit or should I just get a 350 pump and tee the return lines?
    Also, what remanufactured pumps do yall suggest? The one I have is from Napa but they think fairly highly their pumps. I am a little afraid of the A1-Cardone stuff the chain stores sell.
  2. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    The diesel uses a different block and; therefore, different brackets. You will need to get the pump and brackets for a small block. You might look for one that came in a one ton van or possibly a one ton truck with a SB. Or you can just tee the lines together, they go to the same place anyway.
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    hydro boost was used on 1 tons so you should be able to snag SBC brackets at the wrecker from one
  4. BigJohnson
    Jan 22, 2001
    207
    AL
    I have a diesel w/AC version pump now with sbc brackets. It works because the resivor is the extended can type. That is what I want to avoid. I guess I can't do that without finding some sbc 1 ton brackets.
    How bad would it be to use a 350 pump and tee the lines? Are the hydraboost ps pumps any stonger or will a 350 pump work? Anyone have prefrences on rebuilt pumps?
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    IMO the pumps are all the same.
    I would check out a remote reservior pump from a Cavalier or vette
    \the Td line is supposed to be a bad thing but I have never actually heard of anyone having related problems
  6. 4x4Freak
    Apr 21, 2002
    792
    Lubbock, TX
    Actually if you really wanted to, you could have another return line connection welded to the SB pump. Of course the weld would have to be really good to prevent leaks.
