Hydraulic assist ram on a hi-steer setup?
Discussion in 'The Garage' started by Sandman, Dec 13, 2002.
  1. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I am sticking the hi-steer on this weekend and next is the hydraulic ram for the assist steering. How did you mount the ram? I'd like to do it only once. Thanks. Oh yeah, my lift is 6" and I am moving the axle formward 1.5 inches if it matters.
  2. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    I can send you a pic of mine, but will have to wait till I get my springs back on. Basically used 3/8 wall DOM off the axle tube by the driver side spring. Put a small bend in it and went up to the height I needed then added tabs. The back end is attached there and the rod end attaches over the diff. Had to clearance the nut a little, but it all works well. Was nice to get all of it up out of the way as the rocks here in Colorado just love tie rods or anything that hangs down. /forums/images/graemlins/grin.gif
  3. CK5
    May 19, 1999
    21,625
    702
    CO
    Here's mine, just be sure to use tie rod ends on the tie rod instead of drag link ends. I first went with all draglink ends because I wanted all four to be the same and I wanted the high angle of the drag link ends. So now I just have to switch to tie rod ends on the tie rod and should be OK, I love the setup and keeps everything off the rocks.
  4. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Thanks for the pic. Are the tie rod ends stronger? I was thinking of that also. Also I see that the tie rod sits behind the draglink. I was thinking of putting it the other way around. What are the pros cons to that? Thanks.
  5. CK5
    May 19, 1999
    21,625
    702
    CO
    In the case of a tie rod, yes TRE's are stronger because of the thread going right up to the housing (not sure what they call that) and being shorter.
    You wouldn't be able to put the tierod out in front of the draglink without hitting the pitman arm with a conventional GM steering setup.
  6. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I'll most likely just get the rock ring like you did. Should make it easier to fab up the mounts. I didnt know that about the draglink but I guess I would have figured it out sooner ar later. /forums/images/graemlins/thumb.gif
  7. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Steve, Would you happen to have a picture of the TRE vs DLE so we can see the differences? Also are these half ton ends or heavier?
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    HAs anyone done this with a 10bolt or D44?
  9. CK5
    May 19, 1999
    21,625
    702
    CO
    The one on the top is a DRE (1 ton high angle) and the one on the bottom a TRE, you don't need the high angle DRE on the tie rod because it is always on the same plane.
    This pics shows where I have been bending the DRE on the tie rod.
