hydraulic assist with 4x4 box ?
Discussion in 'The Garage' started by TOMER, Nov 15, 2004.
  1. TOMER
    TOMER Registered Member
    Sep 20, 2002
    38
    Israel
    Hello guys
    I would like to know if it possible to drill 4x4 streeing box for the hydraulic assist?
    thanks
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    Re: hydraulic assist with 4x4 box
    it is possible it is the same as a 2wd box except for the sector shaft.
  3. TOMER
    Sep 20, 2002
    38
    Israel
    Hi boz42
    Sorry but what is this "sector shaft"
    P.S Forget to mention that I dont want to go with the crossover ($$$) for now
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    The sector shaft is the part that the pitman arms attaches to, the stock one only lets you turn it left and right, you need it to turn front to back. /forums/images/graemlins/thumb.gif
  5. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    You've got that backwards.
    You could run Hyd assist without crossover but you would rip the box from the frame if you were ever to articulate the axle and force it to steer at the same time with the ram. All you would have to do it let the front drivers side tire get down in a hole and the force the steering and /forums/images/graemlins/doah.gif it would be all over.
    Maybey if you get the bolt on brace from Tim or ORD it might be able to withstand the forces but don't quote me on it....
  6. TOMER
    Sep 20, 2002
    38
    Israel
    This doesnt sound very promising /forums/images/graemlins/yikes.gif
    I probably will order from ORD the crossover /forums/images/graemlins/waytogo.gif (very regretfully I didnt do it sooner,with the shackel flip that already arrived /forums/images/graemlins/screwy.gif).
    tomer
