Hydraulic Clutch conversion
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DieselDan, Feb 16, 2001.
  1. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Does anyone know how different the older linkage (clutch) pedal is compared to the later style hydraulic pedal. Could it be converted? Or is it completely different and must be replaced? What year(s) did GM start using hydraulic? I'm planning on ditching the slush box sometime but I'm not crazy about the old style linkage I got with my SM465.
    TIA
  2. dyeager535
    26,980
    I *think* '85 was the first year of hydraulic. The pedals bolt in, but you have to drill two holes in the firewall for studs that protrude into the engine bay. The studs both reinforce the pedal assembly mounting, plus provide mounts for the clutch master cylinder. I was going to use older stuff until I found a hydraulic setup. The old stuff fit fine in my '86, but it didn't even have the dimple in the floor for the mech. style clutch pushrod. I like the hydraulic quite a bit. Besides being slightly afraid of the bellhousing slave cylinder ear breaking off, I don't see there being much problems with it, besides the cost of rebuilt slave/master cylinders, which are kinda pricey.
    Dorian
  3. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    I converted my '87 to a stick. There are 2 dimples on the firewall which I drilled
    out and then had perfectly located master cyl holes. I used a chassis punch for the
    master cyl center hole. Bought most of the stuff from the dealer. The studs Dorian mentioned
    are VERY important. They are actually studs and rods combined. I posted a parts
    list for my conversion at: http://www.geocities.com/tneg50/ (includes the part numbers
    for the studs)
    SteveB
  4. DieselDan
    Jan 27, 2001
    1,056
    Vermont
    Thanks Dorian & Steve. Steve have you got a better link for your parts list? I couldn't get it to work.
