Hydraulic Clutch Master Cylinder Reservoir
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gnihcraes, Nov 2, 2006.
  1. gnihcraes
    gnihcraes Registered Member
    Mar 1, 2006
    36
    Lakewood, CO
    I searched the forums but didn't find the info I need.
    1985 K3500 Rubber hose from Resevoir to Master Cylinder (resevoir is on firewall and feeds to the master cylinder through this line) - mine is all dry and cracked, can I just replace it with a piece of fuel line? I'm afraid it will bust a leak someday and leave me heavy footed.
    Thanks, Kelly.
  2. sweetk30
    Nov 1, 2004
    25,538
    538
    horseheads , ny 14845
    i need this info also. my doner stuff is ready to install. but my hose is busted and leaked out.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I don't know about gas line, but there are hoses rated for hydraulic fluid, those that you hook up on your tranny cooler lines, those should be fine with the brake fluid
  4. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    I scooped the plastic resevoir and hose from a '95 Ford Ranger at the junkyard. Works awesome, but the hose is slightly larger than factory GM I guess. I just added a small hose clamp and it's fine.
    Just a possible alternative.
    Might also be able to find the correct GM stuff from www.lmctruck.com
    Rene
