hydraulic clutch question
Discussion in 'The Garage' started by clarkjw24, Sep 26, 2005.
  1. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Lets say I've got a 86 jeep commanche with a 2.5 and t4 and I can't get any clutch pedal. Hypothetical of course. :whistle:
    1st I replaced the slave cylinder with a reman from advance. Bleed lines and no clutch.
    2nd I replaced master clutch cylinder, bleed the lines and no clutch.
    3rd I replaced clutch, pp, and release bearing, still no clutch.
    When I bleed the lines I'm not feeling any pressure at the pedal or any really good blowout at the slave bleeder valve.
    Is it possible I got a bad slave cylinder? Any ideas or suggestions?
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Is there a flex line?
    If so, could have a flap in it just like rubber brake hoses will do on occasion.
  3. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Could be the line. The ends are metal tubing with the center a flex hose.
    How hard should the slave be to push in? I've had it out and can push it in by hand.
  4. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    Vacume bleed it. That's what I finally did and it worked great instantly.
