Hydraulic clutch????
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by JohnSPledg, Aug 22, 2001.
  1. JohnSPledg
    JohnSPledg 1/2 ton status
    Feb 22, 2001
    141
    Baton Rouge, La
    Does anyone know of a kit to install a hydraulic clutch on a 72 K5 4x4 with an sm465 4speed? My legs are killing me in traffic, but I don't want to give up the standard tranny.
  2. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    Here is some info that could be made to work for the K5's.
    <a target="_blank" href=http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=133091&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1>http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=133091&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1</a>
    Talk to Grim, I am sure he can answer more ?'s
    See Ya,
    Keith
    [​IMG] <font color=green>Born to Drive My K5</font color=green> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/californiak5>CaliforniaK5's Pictures</a>
  3. Chevy409
    Chevy409 Registered Member
    Mar 5, 2001
    81
    Nice, thanks Cal, I had this same question. Getting sick of my clutch linkage failing when it gets a little twisty!
  4. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    My solution would be to dump whatever clutch you have and go with a Centerforce II before trying to go with a hydraulic setup. The Centerforce II with modified mechanical linkage in my Blazer takes less pedal effort to funciton than the hydraulic clutch in my Fiero (Centerforce I setup) does. It also has better pedal feel and is smoother than the hydraulic setup in my Fiero.
    Anyhow, nobody I know of makes a kit, but I remember that Ken Brown had a hyurdaulic setup on his '72 Blazer that used a Fiero clutch master. I don't recall what slave he used, but I think that later he went to a late-model GM bellhousing with an internal hydraulic throwout setup (because he has an NV4500). I cna't find Ken any more, so I don't know much else I can tell you.
  5. SilverJim
    SilverJim 1/2 ton status
    Sep 23, 2000
    105
    Evergreen
    I used a wilwood master cylinder and a McLeod hydraulic throwout bearing...I haven't used it yet because I'm still in the buildup phase but I expect it to work very well.
    1970 GMC Jimmy 502HO/SM465/NP205 doesn't run just yet!
  6. Tims72
    Tims72 Registered Member
    May 20, 2001
    39
    Lodi, Ca.
    Steve, You said to use a CenterForce II clutch. Do you know what the numbers are for the clutch? I went to the Center Force web site and they didn't list one for a blazer.
  7. Rhody
    Rhody Registered Member
    Oct 8, 2001
    22
    Wallingford, WA
    Hey Tim I was looking into a clutch from Centerforce but decided against it Here is the info I got
    Centerforce II part number CFT361909 $232.95
    TO bearing N1716 $39.95
    Little Rhody
  8. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    I replaced all the nylon bushings in my Z-Bar, welded the wear spots in the clutch pedal to z-bar rod and ground them smooth, then replaced the adjusting rod with a Heim joint and threaded rod and my clutch is way better than before. It's much smoother and easier to push. I've gotten pretty twisty in my truck and my clutch linkage has never failed. Are your motor mounts and cab mounts in good shape?
    Never said I could spell!
    '70 K-20 San Diego, CA
  9. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    here are some notes i have. i'll probably go with this setup.
    ARQ.
    http://www.afcoracing.com
    AFCO part numbers:
    Master Cylinder #CN701-3/4 $49.95
    Slave Cylinder #CN305-G $62.65
    You can buy an adjustable pushrod or make your own.
    offroad baja!!!
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer
    <a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>My Pics</a>
