hydraulic clutches: turning/resurfacing flywheel
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Oct 31, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you cant resurface a flywheel when truck has hydro clutch, correct ? just making sure because we replaced clutch on 95 K1500 and hahve tons of pedal freeplay, flywheel turned at least .090" that we know of in the past.
    thanks
  2. JeremyK5
    JeremyK5 1/2 ton status Premium Member
    Aug 12, 2001
    549
    Indiana
    When I had my flywheel turned on my s10 with a hydro clutch, they gave me a special shim to mount between the crank and the flywheel to make up for the amount they machined off. It worked great, no problems with my cluch at all.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    see thats what they should have doen, but they are just going to do it right and put new flywheel on, 50 soem bucks auto zone and 80 some bucks napa and both places have to order it
    thanks
  4. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    $140 at advance.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    advance doesnt exist here
    thanks
  6. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    bout $180 at O'reilly, $50 - $80 is way low in my experience for a new one
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I payed $75 for my 1 piece RMS flywheel for my truck and that's with my autozoner discount. I don't know how the hell you're getting a flywheel that cheap but I'd check again. Dealer gets $150 for one.
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    95 chevy 1.2 ton 4x4 manual trans flyhwele part number 488235 $ 56.99 and 105.99 core charge,
    youre getting ripped then lol
    sucker.......! /forums/images/graemlins/rotfl.gif
  10. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    well crap. that sucks. what kind of flywheel do i need for my 2 piece RMS engine then? are they the same? the one i have needs resurfaced.
    thanks
    Grant
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    105.99 core charge
    Considering I never had a core to begin with, that'd probably be why that wouldn't work out.
  12. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    anybody?
    grant
  13. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    need a flywheel for 85-older engines except 400sbc and 454
    common easy to find, if i had known anyone needed one i scrapped a good one i had no use for, about two weeks ago,
    also if you have an 85 then its most likely hydro clutch and 85 was first year for this, 85 is oddball two piece rear with hydro,
  14. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    Not to raid this post but I put in a post the other day and asked if flywheels could be resurfaced and they said you could do this. Now is this true or not. I have a hydralic clutch is it a good idea or should I buy a new one? Thanks again
  15. dyeager535
    26,980
    I've got a resurfaced one on my brand new motor sitting in my truck with the hydraulic clutch, and the pedal feels ok so far, although the truck isn't on the road yet.
    If it were a problem, no GM truck after '85 could use a turned flywheel, and I doubt this is the case. I would expect the machine shop that was asked to do the work would tell you if it were impossible.. Don't know if my '86 preliminary shop manual covers flywheel turning not, but if I run across the manual, I'll check.
  16. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    mine is not that bad. just surface rust. im just going to take some 80 grit to it i think.
    grant
  17. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I had the flywheel on my 454 resurfaced and it feels GREAT (I swapped the 700 for a 465 with a hydro clutch). I had a NEW flywheel behind the 350 with a Centerforce DF clutch. Noy I have the resurfaced BBC flywheel with a LUK ProGold clutch. I like the way the LUK feels over the way the centerforce did (even though the pressure plate for BOTH clutchs are made by LUK
    Chris
