Hydraulic Floor Jack
Discussion in 'The Garage' started by okie k5, Jun 5, 2005.
  1. okie k5
    okie k5 Registered Member
    Oct 27, 2003
    74
    Moore, OK
    Does anyone know anything about hydraulic floor jacks. I looked at this one I got for free and I can't figure out what it's problem is. You can raise the jack roughly 2 strokes before the it stops working full stroke. After 5 strokes total you can't get it any higher. I have filled the fluid and I have cycled it 8 or 9 times each time refilling the fluid after. It is Hein Warner (sp) and is a pretty robust jack. I just need to get it working.
  2. texas78k5
    texas78k5 Registered Member
    Apr 24, 2005
    26
    Kerens, TX
    Are you sure the release valve(lowering thinggy) is closed all the way?
  3. okie k5
    Oct 27, 2003
    74
    Moore, OK
    Release Vavle Thing
    I am pretty sure it is closed It will hold weight at whatever height it is at.
  4. Wes Harden
    Wes Harden Registered Member
    May 28, 2005
    29
    Southern Califorina
    good jack
    Hien warner are nice jacks even if you have to spend $100.00 to get it fix it's worth it. When my little 1 1/4 ton HW was stolen the insrunce comp valvued it $1200.00 that was 15 years ago on 30 year old jack.
    Only thing I can think off is to greese all the arms and piviot point, check to make sure nothing is bent or binding. One question is the hyralic cylinder single or double acting. If double acting the the oil on the top/ram side may be blocked by a bad check valve. If single acting the ram cup may leaked to much fluid past it, and as you apply pressure it's dead heading agianst the oil trapped above the cup.
    Good luck let us know what you find.
    Wes :o
  5. gambit420s
    gambit420s 1/2 ton status
    May 17, 2005
    294
    KnoxVegas, Tennessee
    check the fluid you just put in the jack and look for contamination; water, rust, pieces of the seals, if it will hold a load the piston is ok, you are probably leaking pressure in the pump. go for a new seal kit if you can find one or go to an auto parts store and match up your orings.(metric i think for heinwarner)
  6. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    I agree... my last jack leaked fluid and after so long... it would only go up so far.. add more fluid and worked fine... just threw it out as it was getting annoying with the leak all over my garage...
  7. okie k5
    Oct 27, 2003
    74
    Moore, OK
    Thanks for the info
    I found a company called Blackhawk that offers a rebuild kit for it. It is like $65 so I think I will probably do that. Thanks for all the input.
