Hydraulic ram assist steering, What size cylinder?
Discussion in 'The Garage' started by backyardbuilt, Mar 9, 2003.
  1. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    With all the searching I have done I found most guys use the 1.5" ram and there is a 2" ram out there. Is this just for space reasons I can get a 3" ram for next to nothing. Also what stroke do you need I saw 8" stroke 4"s either direction is typically what everyone is using. Having enough fluid is not a problem I'm using a remote reservoir from a van. Is there a link for how to modify your power steering pump for higher output. Thanks for your help, Ryan
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    On the WTO page there is an article on how to modify your PS pump.
    I use a 1.5" ram with an 8" stroke and it is ideal.
    The 3" ram would be VERY slow and I think that is a bad idea.
    -- Mike
  3. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Hey Ryan,
    I have the WTO 1.5" setup and have yet to bind it where it wouldn't turn. The 1.5" is quick enough for the street and good on the trail. The 3" would be overkill. Your pump couldn't keep up with the that large of a ram and probably wouldn't be streetable (it would turn very slow). I am happy with the 1.5", imo.
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    SAVAGE1 has the 1.75" ram on his DD rig that is also the GM of the month. He likes it.
  5. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I also run the 1.75" ram on my dd and I like it /forums/images/graemlins/thumb.gif
  6. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    That is what I figured just didn't want to believe it since I can get such a deal (5$) on the 3" that is the smallest the place has. Oh well back to the drawing board. Thanks for the replies. Ryan
