Hydraulic rams?
Discussion in 'The Garage' started by CCRider, Jan 2, 2003.
  1. CCRider
    CCRider 1/2 ton status
    Jul 8, 2001
    314
    Charlotte North Carolina
    Does anyone know what is the best hydro ram out there , does anyone know what kind offroad unlimited uses , or the one on UAV , looking for an aluminum body , rebuildable , NON LEAKING, 1.5" or 1.75" unit with -6 fittings on it 1/2or bigger heim ends 8" travel , are the agr rams as bad as I've heard they are? Not looking for tractor/farm impelment rams. Thanks.............................CC /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  2. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I've got the West Texas Offroad kit with the 1.75" ram with heim ends and 8" travel. Doesn't leak and I'm very pleased with the whole kit /forums/images/graemlins/thumb.gif
  3. CCRider
    Jul 8, 2001
    314
    do you have any pics? is it the one on UAV? .............CC /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  4. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    Same company as the UAV but he has the 1.5" ram, its supposed to be faster. Here's a pic of mine:
    I had severe death wobble after installing my D60 and Xover, the WTO kit solved this for me and it turns my 42's easily.
  5. CCRider
    Jul 8, 2001
    314
    is it alum or steel? is that a track bar on the front , and does it limit articulation? ................CC /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  6. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    That sure is a nice hydro setup.I was just wondering about the overall strength of the ram.It looks like the shaft of the ram is very small in comparison to everything else.Just curious cause ive seen sooooo many agr rams bent like pretzels.......Farm implement may look crude but its made to handle alot of sh@t.........
  7. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    I'm not sure if its alum or steel, I'm guessing steel. Mabye Matt from WTO will will post this info.
    Yes thats a trac bar I built (before I got the Hydro Assist) to try and solve my Death Wobble problem. It helped when I drove it with 35's but as soon as I put the 42's back on it returned. I haven't flexed it yet but I'm sure it will limit the flex, or will cause the frame to flex where it is mounted. It goes from the driver's side bumpstop bracket to the pass side spring plate. I talked to Stephen at ORD about this and he had a front trac bar on his coilover setup and it broke at the frame mount. Mine was a quick little ghetto fab job to try to test the DW characteristics. I don't run it anymore.
  8. CCRider
    Jul 8, 2001
    314
    Yeah I had thought about doing that at one time also with a trac bar , but I coldn't see how it WOULDN'T limit articulation and travel with a leaf spring setup , I was amazed how easily I can turn the wheels by hand with the 60 instead of the 10 bolt front with ball joints!!!! I'm sure that has something to do with the 60's being more prone to DW !!! ..................CC /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  9. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    The kingpins really dont have any bearing preload like the ball joints did. I still have some DW, so I need to do the WTO kit as well. I hate DW, the 40's on the trail rock though. Ask Grim, he was eating my clods for a little bit yesterday!
    Depdog
  10. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    Glen, are you gonna stick with your low steer set up, or are you gonna go hysteer like keith??
    Oh yeah, since I am too lazy to search, will I need a 1" block under the arms with my 4" rough country springs??
    Thanks rob
  11. Depdog
    1,657
    Georgia
    I like my low steer just fine. I have a RockRod from Rockstomper and the ORD steering arm. My tie rod is above the bottom of my Dana 60 axle and I dont like the idea of putting all the extra torque straight into the top of the steering knuckle.
    Depdog
  12. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    The rams i sell are Steel bodied for rock damage resitance. But the piston and top gland are Aircraft aluminum.
    I have them in 1.75 and 1.5" bore sizes and 6 and 8" strokes.
    They are 150 each.
  13. Depdog
    1,657
    Georgia
    Matt do the 1.5" and the 1.75" have the same shaft diam.?
    Is the 1.75" still suitible (fast enough) for street driving as well?
    Depdog
  14. TheLakeRat
    Nov 29, 2001
    363
    Both size rams have a 5/8" rod size but i do have a few 1.5' rams with a 1/2" rod left but only a few.
  15. CCRider
    Jul 8, 2001
    314
    Is the one on fox's UAV a 1.75 , I like that one !!! How much is max pressure in the ram lines, and I need an answer to depdogs Q as well!! street with 1.75?............CC /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  16. TheLakeRat
    Nov 29, 2001
    363
    Steve is using a 1.5x8.
    the ram lines that i use are rated up to 3000 i think but a power steering box can only handle up to about 1300-1500 psi
  17. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    My setup pictured above (1.75" ram) is my daily driver. There is no problem with the ram speed and city driving, I work in downtown Oakland /forums/images/graemlins/grin.gif I chose the 1.75 over the 1.5 because I'm on 42's. I'm not sure if it makes a differnce, but as far as speed, the 1.75 is plenty fast. My steering feels tighter and more responsive, not sluggish at all /forums/images/graemlins/thumb.gif
