Hydraulic Steering Question
Discussion in 'The Garage' started by kkyle69, Jun 20, 2005.
  1. kkyle69
    kkyle69 Registered Member
    Mar 9, 2005
    13
    Huntsville, Texas
    I,ve recently bought 2.5 ton rockwells. I have a full hydro steering setup with a double cylinder ram that has a 10 inch stroke. Does anyone have pictures that they could post of how they set up the ram on the axle? I'm looking for ideas before I tackle the project. Can I put the ram in place of the tie rod or should I keep the tie rod also?
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
  3. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    This is how I will be mounting mine. I am going to cut the tie rod and use the outer tie rod ends to attach to the knuckle and use heims to attach to the ram...
  4. kkyle69
    Mar 9, 2005
    13
    Huntsville, Texas
    So actually I don't have to use the tie rod? I could just use the ram in its place?
  5. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    You are wanting to run a double ended ram, right? If so, then yes you can replace the long tie rod with the ram and two short tie rods.
  6. kkyle69
    Mar 9, 2005
    13
    Huntsville, Texas
    Thanks for the info!
