Hydraulic Throw-Out bearing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DieselDan, Feb 25, 2001.
  1. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Anybody have any experience with a hydraulic throw-out bearing? I'm contemplating using one for my manual trans conversion.
  2. dyeager535
    26,979
    Can you clue me in on what this is?? I've never heard of such an animal. Is the hydraulic slave cylinder directly attached to the throwout bearing or something?
    Dorian
  3. DieselDan
    Jan 27, 2001
    1,056
    Vermont
    A hydraulic T/O bearing does double duty. It expands and contracts moving the clutch fingers in/out without need for a fork or slave cylinder/linkage. The ones I've seen have a fluid line running in to the bearing (through the opening where the fork would be) and a bleeder line comming back out. They're pricey and more popular with the Street Rod crowd; i don't know many street rodders.
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    These types of TO's were started in 85 on all K-series trucks. They replace the fork, etc. They also have a fluid cylinder that mounts on the firewall under the brake booster. This is the place to fill the system up with the fluid. This set up is very effective. The whole set up also uses a different bell housing instead of the one that uses manual type clutch.
  5. dyeager535
    26,979
    They were? K as in 10-30?? Hydraulic slave cylinders started then, I know this much. Hes talking about a totally different animal that uses no clutch fork than what I have on my K5! What trucks received this?
    Dorian
