Hydro assist dana 60
Discussion in 'The Garage' started by 53chevy, Dec 12, 2006.
  1. 53chevy
    53chevy 1/2 ton status Premium Member
    Dec 29, 2004
    369
    7
    pitcairn
    I've searched and can't find the place where some of you guys bought your parts at (ram). I'm pretty sure its a tractor place. I know its not northern tool though. Thanks
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Prett much any tractor place will do. 2x8 tie rod ram.
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i bought my stuff from him and ive had it on for 9months, no problems. hes a great guy to deal with
  5. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,994
    130
  6. 53chevy
    Dec 29, 2004
    369
    7
    pitcairn
    yea thats what it is, thanks
    Do you think this will work just putting it in where the steering damper goes.
  7. 53chevy
    Dec 29, 2004
    369
    7
    pitcairn
  8. 53chevy
    Dec 29, 2004
    369
    7
    pitcairn
    SWIVEL BALL END CYLINDER
    Brand new, welded cylinder with wire-lock gland retainer. Swivel ball joints at both ends allow for angular motion.
    SPECIFICATIONS
    • Double acting
    • Bore x stroke 1-1/2" x 8"
    • PSI max. 3,000
    • Rod dia. 1"
    • Push/Pull force 5,298 / 2,943 lbs.
    • Ports SAE 6
    • Retracted length 15-1/4"
    • Shpg. 9 lbs.
    END MOUNTINGS
    • Rod end swivel-ball
    • Ball width 1"
    • Ball O.D. 2"
    • Pin hole 0.75"
    • Base end swivel-ball
    • Ball width 1"
    • Ball O.D. 2"
    • Pin hole 0.75"
  9. 53chevy
    Dec 29, 2004
    369
    7
    pitcairn
    I was also think of useing the EMS caps just to make life easier, get some 48" hoses, and what types of connections would i need for the hose to ram and the hose to caps?
  10. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I have the cap from JKWOFFROAD he is also a vendor on here. it is not as tall as the EMS cap and also it is drilled and tapped 3/8 NPT vice 1/4 NPT if that is a concern for you at all. I am running -6 AN fittings on my lines and I have 3/8 NPT to -6AN Male to Male fittings to connect the hose to the cap. I paid aboot $12 for 4 at my local hydraulic shop. They are steel, the aluminum ones are more expensive and I am not sure if they will hold the pressure of my pump.
    Ira
  11. 53chevy
    Dec 29, 2004
    369
    7
    pitcairn
    do you think the ram is too long? whats the lenght on others, and are the joints correct
  12. sandawgk5
    Oct 28, 2003
    6,881
    I have a PSC 1.75" X 8" ram with -6 fittings. The heims on it are 5/8. If you are not running high steer then you need an 8" ram. With high steer it is shorter like 6.5".
    Ira
  13. 53chevy
    Dec 29, 2004
    369
    7
    pitcairn
    so that ram should be fine to fit.
  14. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    thats where mine is currently, with an 1.25" tie-rod. the stock tie-rod wont hold up to the hydro, it will just bend
  15. 53chevy
    Dec 29, 2004
    369
    7
    pitcairn
    caps are the same for 2wd and 4wd, right, same kida of pump just different, both signsaw
  16. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    I know 2943 lbs of force is a lot, but wouldn't you want something more balanced?
  17. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i agree, one way would definitely steer better than the other way
  18. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    PSC motorsports sells a very nice ram, in fact you can get a ram with all hardware for about 200.00 then add a pair of lines and you're good to go. I've researched a bunch of different companies before i choose PSC and i'm VERY happy with the quality of the ram.
  19. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    what ram is everybody running that has ord high steer arms?
  20. 1977k5
    May 26, 2003
    9,994
    130
    Its much better to have a ram that is too strong (the right amount of pull in one direction and too much push in the other) than to have a ram that is bent because the shaft is too small.
    I run a 1.5x8 ram with a 1" shaft and any unbalance in push/pull is not noticeable.
