hydro assist ...help
Discussion in 'The Garage' started by blublaz, Jul 20, 2005.
  1. blublaz
    blublaz 1/2 ton status
    Nov 6, 2004
    145
    Tucson AZ
    im going to put hydro assist on my blazer ,and have heard it was possible to put the ram where the sterring shock is .Does anyone have a good close up pic of this or any other ideas? i have a 44 without crossover, my ram is 2 inch w/8inch of stroke....i have everything i need except placement of parts ...Thanks Don
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    As I said on Pirate, dont do it, with the stock steering you will bend/break your draglink with the ram.
  3. blublaz
    Nov 6, 2004
    145
    Tucson AZ
    isnt there a way that i can either bump stop or adjust so it doesnt hurt anything?????i just cant afford xover yet
  4. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    With the push pull steering, when you flex the front your will get to a point to where you just cant turn. This is a effect of the push pull steering and it is a bind in the draglink since it is so short. Now if you have a ram pushing against that bind something has to give.
  5. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    No, that is final.
    It isn't the power of the system that limits standard steering, it is the geometry. That is why x-over is a must. Also the force that a 2" ram exerts will ruin a stock tie rod quickly.
  6. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    agreed... wait for x-over. Crossover doesn't have to be excessively expensive. Shop around a lot. I recommend WFO Concepts and Black Widow Perf. Both are ck5 members and have competitive prices.
    j
  7. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    what if he went with crossover, would it fit then? What about on a Dana 60?
  8. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Yep it would fit, but you will have to weld some tabs onto the tie rod.
