Hydro assist mount question?
Discussion in 'The Garage' started by southernspeed, Oct 19, 2004.
  1. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Just about to make brackets to take the ram when I noticed that the tie rod rises and falls a couple of inches when you go from lock to lock. It also moves toward and away from the axle as it does so. My ram has an eye on each end which will only allow movement in one plane.
    How do you guys with hydro get around it? Big hole , small bolt?? rod end bearings at both ends would do it but very expensive. Any ideas, comments, pics would be greatly appreciated. /forums/images/graemlins/waytogo.gif
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    my ram has hiems on both ends, it doesn't need to move a lot.
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Yeah, I think I'll have to go that way. Seen a lot of pics of rams that are mounted rigid, so only move on one plain but I don't like the idea of the stress it'll put on the tie rod ends and the mounts.
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    My cylinder has hiems on both ends also /forums/images/graemlins/grin.gif
  5. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Any problems mounting your ram on the spring plate? I have hi steer too and it seems its going to be tough mounting it while keeping it out of the pan (only 4" lift).
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    WOW!!! THAT SET UP IS WAAAAY TO CLEAN!!! nice job! /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
  7. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    No kidding. The tires don't even look dirty /forums/images/graemlins/thinking.gif
  8. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    yeah, whats the deal on the spring plate mounting of a ram... Im thinking about doing that when i put my tie rod behind my axle. Has it caused you any problems?
    j
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    What kind of shocks are those that are upside down?
    back on topic......
    Mine is mounted rigid with no issues thus far.....
  10. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I have the 1.5" ram from RockStomper and it has a solid mount on one end and a heim on the other. It works great!!!
  11. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I have had no problems with it mounted to the plate.I made the plate out of 5/8" just to be safe /forums/images/graemlins/grin.gif The springs in the pic are 6" but I have lowered it down to 4 with no clearance issues.
    Thanks /forums/images/graemlins/thumb.gif
    Thats cuz I had just gotten them and had not had them to the mall yet /forums/images/graemlins/tongue.gif
    They are the old model 9000s.Im pretty good at crashing into stuff with my shocks up front somehow and I wanted these to last more than two trips /forums/images/graemlins/grin.gif
    Chris
  12. BlueBlazer
    Feb 15, 2001
    1,940
    Do the ubolts loosen at all, any worries about centering pin shearing?
  13. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    After a hard trip they my loosen a tiny tiny bit if at all.But no concerns.All my U bolts are on my list of "things to re torque" before every trip.Most center pin failures I have seen have been due to loose u bolts and I dont realy wanna change one on the trail /forums/images/graemlins/grin.gif
