Hydro assist psp problem
Discussion in 'The Garage' started by clarkjw24, May 5, 2006.
  1. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Well, I did the hydro assist with pump mods. I'll put about 2 1/2 quarts in the system. I also did the ps boot reducer to external canister for more fluid capacity. The ram moves in and out but only at full left or right lock. I know this because I don't have it hooked to the tie rod yet. My known problem is that now my ps pump is roaring likes its low in fluid. How much fluid with this system now hold and what is the proper way to bleed it? Is it possible that my pump have gone bad in the two weeks I had it off of the truck? Help please and thanks.
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    one of the best ways i have found to bleed a ps system is to use a hand vacuum pump attached at the top of the ps pump. apply some vacuum and let it sit for a while. the vacuum being low pressure will draw the air out of the system because it will be at atmospheric pressure.
    if not, just turn the steering wheel lock to lock, apply the brakes, and keep on untill you bleed the air.
    got any pics of the boot reducer and resivior? dont know how much fluid it should hold.
  3. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Thanks Ryan, I tried pumping the brakes but that didn't help. It just made the roaring in the ps pump louder. I'm wondering if I put the low pressure lines in the right spot on the ps pump resi. Or if my pump is done and I need to swap in a new one.
  4. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    is the fluid all foamy looking?
    what kind of fluid did you use?
  5. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    I just completed the same setup, and didn't have any problems? To bleed the system, I just turned the wheel SLOWLY lock to lock, and let it sit for a couple of minutes each time I went L or R. I did it with the engine NOT RUNNING and the tires off of the ground. No problems at all and done in less than 30 minutes.
  6. chevysmithz71
    chevysmithz71 1/2 ton status
    May 26, 2005
    1,464
    Kingsburg, Ca
    Just finished mine, works great turning the big meats. Not to jack thread or anything buuut, I Just want to know what difference people have felt in the steering while driving? My wheel is a lot tighter to turn while just driving. It was easier with my regular power steering just seems tougher to turn. Is this normal?
  7. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Put the front of your truck on jackstands, hook up your steering linkage, leave the motor OFF, light a big stogie, and crank the wheel back and forth until the cigar is gone. Add fluid as needed, cap everything, fire motor and away you go. The way the box taps work is essentially through feedback from the sector shaft. Therefore, if the steering linkage isn't hooked up, no resistance, meaning no fluid flow to the ram until you've cranked it to full lock. Hook everything up and force the ram back and forth. I promise it'll work.
  8. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Make sure the system can breath! It needs to vent to atmosphere. I didn't vent mine at first and it roared and sucked the extension tube flat!
  9. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Mine is s-l-o-w and I'm only using a 1 1/2 ram I think I'll try notching the end of the presure valve as that's the only pump mod I haven't done yet.
  10. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    my steering is pretty fast with rocklogic 1.5" ram. mine was roaring at first, probably cuz the fluid hadnt gotten all throughout the system yet. after a couple turns it worked perfectly. i did the pump mods except for notching pressure valve
  11. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    It's strange how much they vary. One thing that occured to me though was that, on my '78 the steering was really light but on my '91 the steering was always heavier which was actually nicer to drive with on the street as it made it feel more stable so I'm figuring there is something about late pumps or boxes that makes the difference.:confused:
  12. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    well i just got a reman psp cuz i blew up the original one without the mods when i first hooked up the hydro assist. my 2wd steering box is off a late 70's truck. can you turn it with one finger?
  13. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Yeah, there's no lack of power in mine but it is slower, as it's always been. I seem to remember reading somewhere that the valving in the pump??? is different on later pumps to give it a better road feel. Can't remember where though....old age i guess!:D
  14. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Thanks guys for all the info. After reading some of your post I realized what the problem was. I was trying to bleed the system without any resistance on the ram. In other words I didn't have the ram mounted, just plumbed. So I welded on the tabs, mounted the ram and cranked it left to right a few times and no more problems. BTW looks like the system only needs about 2 quarts.:doah: :haha:
  15. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    good to hear you got it working right.
  16. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Well, i know thie thread is a month old now but you were asking about pics of the reducer and since no one seemed to have paid any attention to your request and i just got around to viewing this post here is a pic of the boot that i bought from the local Chrysler dealer. The part number is 4333475
