hydro assist q
Discussion in 'The Garage' started by dheavychevy38, Jun 20, 2005.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    Ok i had the setup on my other truck and never had a problem now i put it on my new truck and I have a wandering issue any ideas i bleed the air. Thanks denny
  2. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    ok so i tracked the problem down to when the truck is off and the key is turned so you can move the steering wheel it moves probaly 1/4 turn before anything happens can i adj. the box for this with that nut thanks denny
  3. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    Have someone cycle the wheel back and forth while you inspect each part of the steering system...before you adjust that nut. 99% of the time something is broken, cracked, worn or loose and the box doesn't need any adjustment.
    Rene
  4. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    everything is new in the front there are no cracks i check when the box was off. All new tie rod ends cross over is maybe 1000 miles on it all the king pin bushings and springs and i did the steering shaft with the u-joints in it. So the only thing would be the box but i will double check the wheel bearings those are new too but don't hurt to check. Thanks Denny
  5. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    Double check the box bolts are tight...I've had mine back out a few times now.
    Rene
