hydro assist q's
Discussion in 'The Garage' started by dheavychevy38, Apr 12, 2005.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    Ok i am ready for hydro assist but all the places on the internet sell kits as far as rams and hose. I have access to a hydrolic hose and fitting along with the machine to make them but i can't find just the 1.5 bore by 8 inch stroke ram does anyone know where i can get just the ram thanks Denny
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Rocklogic
    Rockstomper
    WTO
    AGR
  3. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Tractor Supply
    Northern Tool
  4. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    thanks guys just found one 1.5 bore 8 inch stroke 85 bucks thanks.
  5. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    Where??
  6. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I agree, where? I'm using a 2" bore 8" stroke tractor ram that I got for $60. The reason I didn't go with a smaller ram is that they are all $130+
  7. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Here are a couple, but they dont have the heims at the ends.
    Rams
  8. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I'm using the clevis pins in mine. It isn't completely together yet so I haven't had a chance to run it but I've seen plenty of people get away with hydro assist without heims. I wish this link would have been put up a month ago :frown1:
  9. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    A placwe out here in IL i will get the name and # for the place tomorrow for you guys. My boss ordered it for me.
  10. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    The rams list totally different puss vs pull numbers. Does that affect things? Also who has modified a pin style end for a heim?
  11. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    you can't push and pull the same because the rod comes from the pull side and lessens your surface area on the piston
    less area is less room for the pressure to work against. so PSI with less I is less force.
    if thats what you meant :)
  12. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    Well, kinda. I understand how hydraulics work but was wondering if the 1K lbs difference in push v pull was noticeable or any sort of an issue in hydro assist? I am guessing it isn't a big deal but just was wondering.
  13. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    i think they are both overkill, one is just less overkill.
    maybe i dont have enough seat time with it, but i cant notice a difference in speed.
  14. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    That's the one I'm using. You have to cut the one end off and re clock it 45 degrees to keep the fittings off the axle/tie rod.. It works well, I'm locked in front on 42s.
