Hydro assist ram: 1.5" vs. 1.75" HELP
Discussion in 'The Garage' started by MTMike, Apr 14, 2006.
  1. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Since the search fucntion doesn't work with short numbers like those very well, I'll ask this.
    I've been told by many people to avoid the 2" ram because it's too slow... and been told to go with a 1.5".... BUT I 've come across a reasonably priced (not a steal, but not bad either) 1.75" ram with the mounting tabs & heims and wondered how it would compare in speed to a 1.5" ram?
    Would I be satisfied with a 1.75" or should I just buy a 1.5" and remove all doubt?
    This would be going into my trailer queen K10 (Some street duty but only to & from trailheads), 38.5's, HummVee wheels, Welded D60, mainly trails & snow trail runs.
    Thanks for any & all help!
  2. chevyin
    chevyin 1/2 ton status
    Sep 14, 2005
    1,324
    Pismo Bch CA
    When I ordered my ram assist, the guys at west texas offroad said they recommended 2" only for total off-road rigs, 1.5" if you're like 90% on-road, and the 1.75" for a good mix of the two. According to them it should still be very streetable with the 1.75. Ive yet to install it though.
  3. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    If it's only for the trail heads, then the 1.75 should work fine. Heck, I would venture to guess that even a 2" could work good enough for that... depending on how far you have to drive it.
    Everyone says that the 1.5 provides the best steering response for the road in daily driving. That's what I plan to run. I've been trying to find one locally, with no luck. Spent a better part of one day calling all over town.
  4. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
  5. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    I'm running rocklogics 1.5x8 ram. At times, I find it to be a little slow. Making quick turns in parking lots and correcting power slides are two areas that really get to me. I know I know, shouldn't be sliding a big blazer on the street but what ya gonna do when the detroit kicks in?:D Off road, I couldn't have asked for more.
  6. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
  7. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    Im currently running the surplus ram and love it. Ive only been out with it a few times but its payed for itself as far as Im concerned. Laying almost completely on my side, I could still steer and move the truck.:D Havent seen any reason to go bigger(yet).
  8. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    im running the same setup, rocklogic 1.5x8 on the street with detroits. sometimes i wish it would move faster, like when parking or quick turns its a little slower than id like. it might be because it needs a bigger resovior. when wheeling, i love it, the turning speed doesnt bother me at all
  9. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    For those with slow response, have you done the p/s pump mods?
  10. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    yep, i started with a new steering pump and did the mods before i put the pump in. i think my problem is i need more fluid in the system. gatta make a big resovior.
    under normal driving its fine, its when you try to make fast turns, like when parking that u feel it hesitate to keep up. really not a big deal tho.
  11. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    Wow - thats an old thread.
    I ended up getting the 1.5" Rock Logic ram and it's great.... however, I think I need a new/upgraded pump. When the wheels get under load, (ie in snow, or aired down on hard surface) I turn and it starts to move, but then the wheel gets "hard" like I have no power steering at all. The belt sometimes squeels, but sometimes not, but the wheel won't turn without excess force. I should be able to turn it lock to lock with my pinkey but that's not always the case.
    I've done the pump mod, and have done the "radiator hose filler neck extension" to expand resivor volume, both have provided no change in this behavior.
    Ideas?
  12. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    What about a cooler?
  13. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    What, exactly, is everyone doing to modify the pump?
    For those who are experiencing some resistance with quick turns, what size lines are you running?
  14. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
  15. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Adding fluid capacity wont change the speed at all. As long as you have enough room for ther to be fluid for full extension/ retraction then you are good.
  16. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
  17. 53chevy
    53chevy 1/2 ton status Premium Member
    Dec 29, 2004
    369
    7
    pitcairn
  18. 79k20350
    Nov 22, 2004
    7,757
    Ct
