Hydro Assist resevoir help
Discussion in 'The Garage' started by 5trucks, Feb 13, 2007.
  1. 5trucks
    5trucks 1/2 ton status
    Aug 12, 2005
    169
    Yuma Az.
  2. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    maybe on the low pressure return line. If there is such a thing.
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I would get a hose that would connect to the bottom of the resevoir in the picture and attach it with the fitting from dodge to the top of the existing rez and then cap the small line up on the top.
    Connect to the other rez with this part. Post #122. I used that on the top of my existing rez and connected a piece of tubing from the remote to it.
    You can see pics of it here
    Ira
  4. 5trucks
    Aug 12, 2005
    169
    Yuma Az.
    I typed in the part number on dodge and chrysler and both came back no such part.
  5. sandawgk5
    Oct 28, 2003
    6,881
    I think you have to go to the dealer.
    I found mine in the junkyard.
    Ira
  6. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    Sean at Performance Offroad has a Powersteering pump housing which has a #10 fitting inlet on the top of it. Just hook your return line to the top fitting on the resevoir, then hook the bottom one on the resevoir to the pump housing. This setup is actually better then a stock resevoir system because it cycles all of the fluid through the system. A stock type system will usually not use the fluid above the housing.
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Here is what i did. I bought a grommet (part number 4333475) from the Chrysler dealer that attaches to the top of the stock resevoir and then connects with a 3/4" hose to a remote resevoir.
  8. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I just used an extra piece of coolant hose. It gave me the extra capacity i needed and helped me get to the filler with the OBA there. The neck/cap is a Summit item welded to an aluminun tube. Cheap but effective!
  9. 5trucks
    Aug 12, 2005
    169
    Yuma Az.
    Where did you get that res?
  10. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    x2.
  11. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    looks like a hydroboost reservoir
  12. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    thought it looked familiar to something on the 6.2
  13. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Yep, it is from a factory hydroboost truck like Jishory said.
