Hydro assist with the big ram finally done!! PICS TOO
Discussion in 'The Garage' started by backyardbuilt, Sep 3, 2004.
  1. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Finally got it all done and it works great!!!!! Total cost was about 100$ I taped the box myself, got the ram for 59$, hoses for 6.49$ each, and four fittings at 1.50$ each.I got the steel for the brackets for 10$ and spent lots of time on it. Still have to repaint but it is all done. Well on to the pics!!!!!!
  2. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    nuce that is friggen big!!!
    how fast dose it turn, that is my conseren with a dd. /forums/images/graemlins/waytogo.gif
  3. gonecheenin
    gonecheenin 1/2 ton status
    Aug 8, 2004
    111
    Vandergrift, PA
    Isn't the angle you have it on gonna bend the tie rod when the tires wedge up against something? Did you use that angle to calibrate the travel of the cylinder with the travel of the pitman arm?
  4. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    I haven't noticed a difference from my regular steering without it. I drive my truck and I'm not worried at all.
  5. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    The angle looks alot steeper than it is because I took the pics up high but it should be fine. I had the tires turned all the way to the left with the ram fully extended when I welded the bracket on, but the ends of the ram are adjustable to compensate. I will test it on the 18th of sept. on my clubs annual picnic and report back. But a friend has his mounted the same way and it has worked fine for over a year.
  6. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    What size ram did you go with??
  7. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    Looking good! /forums/images/graemlins/waytogo.gif
  8. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    very sexxy!! and for only 100 bucks...I'll take 2 please /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/peace.gif
  9. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    Thanks for the link. Was the ram too long to weld to the axle? So you haven't noticed any issues with the speed being to slow? Did you just mod your pump per WTO? Are those tubing spacers on each side of your brackets, seems easier than trying to use 1" stock.
    Hopefully another week and I can get mine (ram is gonna cost me $72 at the local farm store). All set up, tapped box, modded pump, cooler & extended external resevoir are all in place. I can turn with my pinky right now, but with the tires on the ground, I don't get full lock to lock, it pushes the axle/springs around too much.
  10. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    2" bore 8" stroke
  11. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    Thanks, I am glad it turned out the way I planned!
  12. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    I didn't want to mess with welding to the axle, I wheel pretty crazy and didn't want any issues (60's cost too much for issues). It isn't any slower than my stock steering was, I could steer with my piggy finger too (still can) but with this I know the steering box is gonna stay on the frame and if I do get hung up in the rocks I'll have steering. I haven't modded the pump yet, we will see when I get more than around the block a couple of times to really see how it works. They are spacers and it was alot easier after reading what 84chevy_k10 had to do to get the holes in 1" plate. Thanks for the help on the steering box reseal!!
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Did you mod your pump yet?
    My pump screams but it still turns the tires well. I'm told modding the pump might quiet it down. Is this true?
  14. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    No I didn't, but I had read that to get the air out of the system, to jack the truck up and turn the tires lock to lock 20 or so times. I did that and added fluid till full and no more noise.
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I did that when I first did it, I guess I still have air.
  16. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    when street driveing a hydro assest truck dose the wheel spin back on its own after a trun or do you have to spin it???
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It spins back. Everything that happens with mechanical steering happens with hydro assist....you just have more steering pressure.
    The 2" ram is definitely too big for the street though.
  18. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    i found localy a 1.5x 8" ram for about 85 bucks and thats was the first place i looked so, i think its a nice inbetween. /forums/images/graemlins/waytogo.gif
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Honestly, if my truck was my daily driver, I'd be re-evaluating what I want to use the truck for.
    I survived a long time without it, and mine is a dedicated trail rig.
    I guess the morale of the story is be careful...with enough modification your daily driver might become too capable and you'll take it somewhere you wish you wouldn't have. /forums/images/graemlins/rotfl.gif
  20. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    amen to that, i will be walking to work one day and have to tell my boss who already thinks its stupid and i am crazy that my truck is eather halfway down a moutan or sunken to the center of the earth in some bottomless mud hole /forums/images/graemlins/histerical.gif
    (he thinks it isent a hoby and hes the one with 15 gtos, at least i get to drive my hobbby /forums/images/graemlins/woot.gif)
