hydro assist without crossover?
Discussion in 'The Garage' started by bajaviking, Apr 7, 2006.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    I saw somebody write that hydro without crossover is not a good idea. Is the issue that it is just not the best setup or can you break something or what exactly is the problem.
    I only run 35" tires and a 4" lift but I do wheel it pretty hard and since I am welded up front I would like my steering to have a little more power and also it would take the stress of the frame and other steering components.
    I can't afford a Dana 60 and since the Dana 44 is not any stronger than my current 10 bolt I would prefere to just do the hydro and not spend money on changing my 10 bolt out for a Dana 44 to just to do the crossover.:confused:
  2. cwn anwyn
    cwn anwyn 1/2 ton status Premium Member
    Oct 30, 2002
    1,268
    6
    Falcon CO
    Why change out the whole 10b for a 44 to get crossover, when you can just throw the knuckles on you 10b? Thats what I am in the process of doing.:waytogo:
    Z
  3. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    yes it works with stock steering....a friend did it on his 44,worked fine
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    trouble is, when your flexed and your steering is almost maxed out (but your steering wheel is almost 'straight ahead'), if you then turn your steering wheel the ram will try to turn the wheels when the box can't turn any more and booom!
    Hope that makes sense!:D
  5. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    This is what I did too. Easy job and MuddyTazz has blue prints for correct knuckle machining if you need them.
  6. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yep the problem isn't lack of hydro it's the stock steering geometry. Put a ram on there and "force" it and bad things could happen. I asked this same post a couple years ago, and thats what I was told.
  7. bajaviking
    Apr 10, 2002
    752
    Baja
    Thank you, the explanation makes sense, I don't know how strong the ram actually is, I wonder if I put a small a 1.5" ram, would it be strong enough to break parts? I have no experience with Hydro and I thought since it is only assist maybe it would not be strong enough to actually break parts. In case something breaks what do you think would break?
  8. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I have a 1 1/2 inch ram and it's plenty strong enough to break lots! Most likely to break would be the sector shaft I reckon. Then probebly tearing the box off of your frame would be the next worry. Maybe rod ends?? I'd do the cross over and hydro together if I were you.
    Good luck.
