Hydro Assist
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NEK5, Jan 29, 2006.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    ok what exactly is hydro assist?? is it a replacement for steering stabilizers or can in be used with them??? would anyone recommend it for a blazer with 4 inch lifts and 33x14.5 mickeys but soon to be 12.5??
    i have dw
  2. midnitewarya
    midnitewarya Sounds like a problem for future me. Premium Member
    Dec 1, 2002
    1,726
    20
    SoCal
    Hydro assist is adding a hydraulic ram to your steering box, that connects from the front axle to the tie rod. It replaces the stabilizers. It is used to help out the guys who are running huge meats, like 37s and higher. It works by tappinginto your steering box with two lines, an input and an output. Those two lines run from the box to the hydro ram mounted between the tie rod and axle. When you turn the box, it sends fluid to the ram, which expands it, and "assits" the box in turning the front wheels.
    I've thought about doing it, but I only run 35s and am not serious enough off road to need it. I don't think you'll need it with 33's and a healthy steering system.
    Al
  3. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    ok thanks for the input!
