hydro bellhousing swapability
Discussion in 'The Garage' started by camiswelding, Apr 8, 2004.
  1. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    I cant seem to find a reasonable 85-91 vr (and k before 87) series hydro bellhousing so I can do the hydro swap into my 81 k5.....
    I did find a 89 k series gen three bellhousing behind an sm465... the slave cylinder is on the pass side instead of the drivers...other than that it looks the same... anyone know of any reason why I couldnt use this? I can get the correct pedals etc and I was thinking I could just run a longer line fron the master cylinder...
    anyone done this or have knowledge if this is feasible...
    FYI apparently GRUMAN vans with smallblocks also have the correct hydro setup for gen 2 trucks... like theres any of those around in the junkyards....
    thanks
    cam
  2. ilikemud
    ilikemud 1/2 ton status
    May 22, 2003
    111
    The Farmhouse, NJ
    there is one on ebay now with slave cyl. on drivers side not a bad price as of yet... cant really help u out other than that... sorry
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    there may be a clearance problem with the front drive shaft, i think thats why gm changed the sides
  4. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    good obs on the driveshaft clearance... I didnt even think about that.... you just saved me some hard cash....
    any hydro gurus out there?
  5. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    thanks for the ebay heads up... Im bidding on it but already the price is getting... "proud"
    cam
  6. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    The hydro housings that were originally from our trucks had the slave on the drivers side. I have an 85 bellhousing on my 87 and it is on the drivers...I also used to have an 91 V-body bellhousing with the slave on the drivers...
    The C/K body style truck have the slave on the passengers side for, as mentioned earlier, driveline clearance. With 4+" of lift you should be fine either way. The slave cylinders and shift fork and are different though *I THINK* I have a bellhousing from a 1992 with a NV4500 in the garage and it has a pass. slave...
    Chris
  7. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    anyone have one they want to part with???
    how about pedals and the rest of the setup?
    anyone?
    cam
  8. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Maby an alternate route for you to take.
    www.AdvanceAdapters.com makes a bracket that uses the bell bolts to mount. I just recived mine and it is a nice fit. They use a Toyota LCruzer Slave cylinder. I am in the process of setting mine up. The Master is still GM and I will be atapting the Master to my existing clutch pedel too.
    Here is another alternative
    http://www.novak-adapt.com/catalog/clutch_components.htm
    For me I am installing a FI454 so I wanted to keep my cast bell for strenght so I went the AA route so I can customize to my liking/needs.
    Anyway good luck... /forums/images/graemlins/peace.gif
  9. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    thanks for the aftermarket info
    and link
    cam
  10. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    is it this
