Hydro boost booster needed ASAP
Discussion in 'Parts & Trucks Wanted' started by sandawgk5, Feb 7, 2006.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Title says it all. I need a HB Booster that has the O-ring fittings preferable from an 86 or newer as I know those years bolt up with no problem. Help a CK5 brother out:D
    Ira
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    I have one from an '84 with o-ring fittings... I had it on my '79 when I converted it to a 6.2L... I'm keeping the new hoses though. I want $90 for the booster I know to be in excellent condition. Reman at schucks are going for $157.99 though.
  3. sandawgk5
    Oct 28, 2003
    6,881
    Can you send me some pictures of the unit and some of the pushrod where it connects to the pedal?
    Ira
  4. kennyw
    Jun 9, 2002
    13,224
    94
    I can get pics this weekend when I get home.
  5. sandawgk5
    Oct 28, 2003
    6,881
    Kewl thanks
    Ira
  6. kennyw
    Jun 9, 2002
    13,224
    94
    Here are some pics... I removed the two studs that go into the body because my '79 had studs coming from the body out on the original vacuum booster. Was a pain to get to those two nuts the way I had it and I now know why they reversed them on the hydroboost. Holes are still unaltered and you can put new or used studs back into the mounting plate.
  7. sandawgk5
    Oct 28, 2003
    6,881
    Thanks for the pics. I have 1 more thing to check on my setup then I will be getting back with you will you take 90 shipped to 92021? Also mine is mounted the same as yours and I had to drill the holes to the same size as the others as it would not slide over the studs in the firewall. Those two nuts to suck though.
    Thanks again
    Ira
  8. kennyw
    Jun 9, 2002
    13,224
    94
    I've got another one I can sell you for 90 shipped off of an '82. I just checked it last night and it has the same mounting config and O-ring fittings as well. Only difference is I pulled it from a parts truck I never drove. Truck was driven onto a dealer lot as a trade in, then it sat too long and wouldn't start for them again (bad glowplugs and the weather got cold)... I got it a couple years later from a guy that bought it for the tranny but it sat complete with the hood on and didn't get exposed to the weather.
    I'd pull the master and lines off to ship it...
  9. sandawgk5
    Oct 28, 2003
    6,881
    How much would shipping be to 92021 for the confirmed working one. I would kinda like to not take anymore chances ya know.:D
    Ira
  10. kennyw
    Jun 9, 2002
    13,224
    94
    Looks like it should be close to $20 for FedEx Ground. So $110 to your door.
  11. sandawgk5
    Oct 28, 2003
    6,881
    K thanks I will let you know as soon as I get the cash.
    Ira
  12. kennyw
    Jun 9, 2002
    13,224
    94
    No problem.
