Hydro-boost brakes?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BadDog, Mar 12, 2001.
  1. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    My current project is a K30 that I am cutting down to make a Blazer (sort of). Anyway, it has the hydro-boost power brakes and I have never fooled with them before. Seems to me like just more high pressure lines to leak/blow so I thought maybe I would convert it to vac assist. Does anyone have any compelling knowledge/experience one way or the other?
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  2. baldbandit
    baldbandit 1/2 ton status
    Jun 16, 2000
    282
    Marshall TX
    I have the hydro-boost brakes on my 84 1/2 ton 2x (was a diesel and will soon be gas!) and will be converting to vacume assist when i complete my rebuild. You are deffinately right about the leaks! Everyone says the hydro boost brakes are better. I've had both and realy couldn't tell any difference(sp?).
    baldbandit
    "Have you outdriven a F**D lately?"
    Check out my site!
    <A target="_blank" HREF=http://www.baldbandit.coloradok5.com>http://www.baldbandit.coloradok5.com</A>
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yeah, the only drawback I see is that the vacume booster is bigger and in the way more.
    Bad Dog
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.<P ID="edit"><FONT SIZE=-1>Edited by BadDog on 03/13/01 07:59 AM (server time).</FONT></P>
  4. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I'd stick with the hydroboost and carry spare lines for it. Mine works great, but I did blow a high pressure line last summer, I think it was the original. Its a bit hard to steer 15" wide Swampers w/ no assist and 6 psi.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    On a related point, does the hydro boost cause much in the way of additional heat/aeration problems when used in extreme off-road situations?
    Bad Dog
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Wow, with all the diesel folks on here, I expected to get more feedback on this one. I think I'll just go vacuum to keep things simple and eliminate some pressurized lines. No worries about additional PS heat either.
    Bad Dog
  7. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    For what its worth: All CUCVs and HMMWVs use silicone brake fluid, which is slightly compressable (soft pedal). I believe the Hydraboost compensates alot and provides a pretty firm pedal. I never had a line blow, but ALL CUCVs (and a few HMMWVs) lines weep (no drips, just wetness).
    Some of the big GM Buicks, Caddies (gas) also used hydraboost to work four wheel disk brakes (big brakes, bigger car, little effort).
  8. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    Mom used to have an '84 Caprice wagon w/Hydroboost. Gas 305, 700R4.
    Pete
  9. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
    My 83 had hydroboost and those were the best feeling/working brakes i've ever had. It also frees up a lot of space under the hood.
    Squash
    <A target="_blank" HREF=http://www.trailrunners4x4.org/users/realsquash>http://www.trailrunners4x4.org/users/realsquash</A>
  10. pr1aw
    pr1aw 1/2 ton status
    Sep 17, 2000
    144
    San Diego CA
    Diesels don't keep up with the vaccum demands of vaccum assisted brakes when your at idle hence hydro boost.
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yeah, I know why they are on diesels, but I'm converting to 350TBI. Hence, my original question.
    Bad Dog
  12. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    They are used on a lot of 1 tons, as well as chassis cab and heavy duty applications, ie walk in vans and motor homes. I prefer them to the vaccum assist.
    Pete
