hydro boost conversion on a 75 1 ton
Discussion in 'The Garage' started by 75 1 TON, Jun 8, 2006.
  1. 75 1 TON
    75 1 TON Newbie
    Jun 8, 2006
    ohio
    can anyone tell me what year hydro boost brake booster and master cylinder is best for 42 in tires( best braking) I have vacuume now and both master and booster is bad... also do you need a different pump??? thanks in advance for the help....75 one ton
  2. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    any 3/4 or 1ton will work and get all the p/s pump stuff with lines. but make sure you have dubble 45 flare lines to match up to your old style box. the 80s went oring style. but if planing crossover great time to upgrade to 2x4 box to match.
    and just basic bolt on and blead both systems proporly. only thing needed was remove brake pedel bracket and pop out the 2 studs from the vac system and bolt on the hydro stuff.
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I used a half ton hydroboost setup...You can "T" the return lines and use your old pump, but some people have had issues doing that, including myself. I ordered a reman HB pump, and the two return line nipples improved the performance of my braking.
    The pedal assembly I used (off a HB truck) had a different mount position for the master cylinder rod, and the rod was a different length than the vacuum setup. I recommend getting the pedal and rod when you get the HB unit. Some have used their old pedals, without problems, but I bought the whole thing while I was at the junkyard - I told him from the pedal to the pump.
  4. 75 1 TON
    75 1 TON Newbie
    Jun 8, 2006
    ohio
    thanks for the info guys,but what advantage is the 2x4 stering box??I am planing to get all the parts from advanced auto parts..not one junk yard around here has what I need.Again thanks a lot.....Mark
  5. sweetk30
    Nov 1, 2004
    25,539
    538
    only need the 2x4 box if doing crossover steering swap.
