Hydro Boost help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MaxCrack, Nov 21, 2002.
  1. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    OK. I did a search and found lots of stuff, but nobody seemed to have my problem. I bled the power steering and the hydro booster, with the front end in the air, by turning the wheels and hitting the brake pedal a lot. Stopping for several minutes to get the bubbles out and repeating many many times. The steering eventually stopped making noise, but I still get noise when I hit the brake pedal. Also when I put the truck down and drove up and down the street once, The brakes work great, but make noise, and the power steering is not power steering, meaning it takes a lot of effort to turn, almost like there is no juice getting to the steering box. At the time of installation I also installed a power steering cooler after the T for the two low pressure lines.
    Any ideas/forums/images/graemlins/confused.gif
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Just a guess, but sounds like your cooler may be harboring a big air pocket. Which way is it mounted; fitings up/down/side, inlet/outlet?
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    now that you have run it, put it back in the air and bleed it again. took about 20 minutes when i put the AGR pump on, with Hydro, cooler, etc. it will take at least that, i would imagine.
  4. BlackDog714
    BlackDog714 1/2 ton status
    Jun 8, 2002
    260
    Indiana
    Mine is making the same noise, but I still have steering... I have tried to bleed everything, but it's still making noise. IT's driving me Nucking Futs! /forums/images/graemlins/confused.gif
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i know this sounds silly, but are all the belts lined up? mine aren't and i have problems like what you guys are describing. Dunno. Sounds like DW problems, thet are just there.
  6. BlackDog714
    Jun 8, 2002
    260
    Indiana
    Nope, the sound is coming from the brake pedal, not the engine compartmant.
  7. MaxCrack
    Apr 10, 2001
    895
    Mt View, CA
    The cooler inlet outlets are pointing horizontally with the inlet on the bottom.
    Like this...
    /-------- -->out
    \-------- <--in
    The brakes work great but every time I hit the pedal I get the noise like there is air in the lines somewhere, and when steering I get no noise but it is very difficult to turn the wheel.
  8. DieselDan
    Jan 27, 2001
    1,056
    Vermont
    Well, your cooler is oriented right. If you can, you might try unbolting it and holding (hanging) it lower during bleeding. There's an air bubble int there somewhere. /forums/images/graemlins/grin.gif
  9. MaxCrack
    Apr 10, 2001
    895
    Mt View, CA
    OK, I got around to doing more work on this. I found a rather large leak which was one problem. I had to replace the hose as there was a chunk missing out of the flared end. I also added a radiator hose to make the resavoir larger (before I found the leak I thought this might help, and my York is sitting right ontop of the pump, the hose makes it much easier to add fluid to the power steering)
    Well, the leak is fixed, and the system seems to be fully bled and the steering works great. But, I still have a problem. When I start the engine, the brake pedal goes in by itself and the brakes are applied a little more than lightly. I know all the hoses are hooked up correctly. There is some kind of adjusting thing (at least it looks like what I would expect an adjusting thing to look like) in the front of the booster just above where the master cylinder mounts. Would this do anything? Do I need a different booster (again)? Or can this one be fixed? By me? Or by someone else cheaply?
    Thanks for any help.
  10. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Did you install the brake pedal and pushrod that was from the doner truck? I know they are different and may be causing your brakes to be partially applied.
  11. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I agree with slider, I had a similar experience with that same rod being too long and caused the same results.
  12. MaxCrack
    Apr 10, 2001
    895
    Mt View, CA
    I have the brake pedal from the truck I got the booster from, but I don't need it. When I connected the booster to my brake pedal, the rod is about 1/2" shorter than my original and lines up perfectly. All I had to do was screw in the switch for the brake lights so that they work correctly.
    My problem is that the booster is working all by itself with no input from me. I start the engine and the pedal moves in and applies the brakes.
    I removed the belt today. The brakes work fine with no power, although I do have to push harder. I talked to a guy today that said I may have a damaged check valve.
    (And man! What a bitch it is to steer that thing with the power steering out. 37" tires on normal rims on a dually front end, it almost takes two people to turn. /forums/images/graemlins/grin.gif)
  13. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Oops, I was speaking of the rod between the hydrabooster and the master cylender. Its probalby too long and is actuating the brakes at rest. When you bot the two together, there should be no resistance flushing them up together.
  14. DieselDan
    Jan 27, 2001
    1,056
    Vermont
    My hydrabooster was dragging the brakes last winter. I thought I was getting ready to puke a u-joint (vibration), then I felt the front hubs...WTF? Managed to milk-it for another day, had to stop every few miles, shut off the truck and pump down the hydrabooster. Hey it was frickken COLD! /forums/images/graemlins/eek.gif
    Replaced the booster with another one I had laying around. I looked at the old one but couldn't figure out why it malfunctioned /forums/images/graemlins/confused.gif
  15. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    /forums/images/graemlins/k5.gif on hummers to see if the hydro boost is bad put the brake pedal to the floor before starting the rig then when you start it almost insantly it should pump up if it doesnt bad booster at least it works on hummers! /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif
