hydro boost master cylinder
Discussion in 'The Garage' started by patt107, Jan 1, 2007.
  1. patt107
    patt107 1/2 ton status
    May 15, 2005
    276
    north carolina/new york
  2. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    that'll do it. thats whats on my truck.
  3. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    Looks like it should work, since it is the one called for.
    My advice to you is to install a proportioning valve between the Master Cylinder and the rear brakes. This way you can really tweak the amount of braking between the front and the rear.
    It does not have to be anything fancy. (I installed mine in the cab, which requires a bit more work) It would be much easier to install the valve under the hood near the master cylinder. Once it is dialed in you do not really have to adjust it. It is well worth the time and effort to install one.
