Hydro-boost or 1/2 ton master with hydraulic steering asist?
Discussion in 'The Garage' started by JK5, Jan 7, 2003.
  1. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I did my 1 ton conversion on my k5 a year ago..
    I have stock d60 brakes up front...rear disks with d44 calipers. All rotors were replaced.
    I haven't had any issues with my brakes...I have a real sensitive brake pedal and the truck stops on a dime. Even on steep inclines.
    My question is....will after and brake parts wear...will I have brake issues??....especially after adding weight...cage/tools/bumpers about 400 lbs.
    Also I'm going with hydraulic steering assist. I've heard some horror stories about having hydro-boost and hydro-asist hooked up to the same pump, so I need some input.
    Thanks for you help
    Jerry /forums/images/graemlins/smile.gif
  2. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    the brakes should hold up just fine as long as your rotors don't warp too bad and as long as you don't let the pads get too worn.
    The steering will suffer from the hydro boost brakes. If you want to go that way then i would suggest staying with the 1.5" bore ram.
  3. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Cool....
    I wasn't planning on changing my master....but I do have the hydro-boost set-up sitting on my shelf....just in case.
    I was planning on sending you the gearbox and pump....
    to rebuild and set-up for ram assist.... /forums/images/graemlins/wink.gif
    I'll give you a call later today.
    THanks
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    My 1/2 ton master did not fit the hydroboost booster assembly...
    Rene
  5. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I wasn't looking at bolting the 1/2 ton master to the hydro-boost....rite now I have a stock vacuum booster...and my brakes work SWEET...But since I have the complete hydro-boost set-up with the master brake cylinder, I was wondering if I should use it or not...or if there are any tricks to get the hydro-boost and the ram assist to work well together without any steering or braking problems.
    Congrats on 10,000 /forums/images/graemlins/wink.gif
  6. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I wasn't clear on that part...so I thought I'd pass along the fact it doesn't fit (which was a surprise to me/forums/images/graemlins/crazy.gif)
    Congrats on 10,000
    Proof that I have no life... /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif
    Rene
