hydro-boost Q's
Discussion in 'The Garage' started by neverendingproject, Sep 26, 2005.
  1. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    First off, I have heard nothing but wonderful things on the hydroboost conversion, so I said to myself, "self, we are going to try this."
    So here is what I have. I pulled a hydro-boost unit from a 85 one ton. I have stock brakes on my 84, and soon I will go to rear disc conversion.
    So here is what I need. I need to know if the MC is a good one to use, should I expect any problems, where can I get a rebuild kit and a power steering pump, will it work with my current brakes and future 4wdb?
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    When i swapped the 6.2 diesel into my truck I also swapped the Hydro-boost. The 1/2 ton MC did not fit the hydro-boost unit I got from a one ton...so I swapped the MC as well. Also installed the rear disc brakes while I was at it. I have great pedal feel and the truck stops quickly and easily without early lock-up in the rear. i can threshold brake quite easily.
    For the pump, ask for a pump from a K30 with a small block.
    Rene
  3. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    I got the whole HB unit from the truck, lines and everything. Where do i get a new pump? I would like to not go through the stealership.
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The only difference in the pump is the canister... it has one extra return line fitting. You can get one at a wrecking yard.
    OTOH, if you can braze or weld, you could add the extra fitting yourself. ;)
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    that's wierd, stop it. :D
  6. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    yep found that out after spending $90 for one at Autozone.
    my billet pulleys require a keyed shaft, so i was just going to swap the reso's, need to head back to the PnP to get a $10 reso and return the $90 pump.
  7. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    search the forum... youll find my post "finally better brakes for the v3500"... then go to the tech section and look for the post "why hydroboost brakes" ... between the two it should answer all your questions
    cam
  8. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    I would get a pump made for a hydroboost system. I was running a regular pump for a while and I found that I could turn the wheel faster than the power steering could keep up, especially with brakes applied. When I went back to a hydroboost pump that went away.
    Like Rene said, get a pump for a C30 or K30 with hydroboost. If you need serpentine just specify a 1990. That's is what I'm running.
    Also another note of experience. I've decided that from now one I'm getting my pumps new from the dealer. Yeah it's more money, but I lost a pump that was less than a year old on the trail. No power brakes or steering sucks. The pump was a reman from Carquest. The shaft pulled right out the front of the pump. In the future I'll spend the extra money for a new unit that won't require trail side repair and my wife running all over the mountains to find a store with a pump in stock.
  9. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    my advice is to replace all the lines going to and from it. Ive had issues with the stock ones cracking and making me loose fuild out on the trail.
  10. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    i just checked, for an 84 k5 and k30, partsamerica.com list the same pump part #, only # thats different is if you get the reso with it or not.
  11. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    That was what I had found out initially also, because I was using PartsAmerica.com too. I'm pretty sure that Carquest had different part numbers, but that could be because I ordered it with the reservior.:dunno: I think if you read one of the posts camsk5 referenced, it says that the hydroboost pump runs at a higher pressure. I know it made a difference for me.
  12. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    i know Autozone as well gave me the same number for my 88 k5 as for an 88 k30 for just the pump.
  13. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Okay so I found a hydro boost power steering pump at my uncles junkyard, but it came off a diesel.
    My question is whether or not the mounting holes for the diesel p/s pump are the same for the sbc. I am also curious to see if anyone has rebuilt a pump or booster themselves, and how hard it is.
  14. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Just a thought; but you could always just change the relief valve at the back of the pump (the one behind the high pressure hose). I would bet that the only real difference between Hydraboost steering pumps and just steering pumps.
  15. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    Bingo!
    Just modify or replace that regulator, and either install a second return line, or I have seen in several instances where you can use a T fitting where one branch goes to the hydro-boost, the other to the steering box, and the third back to the pump.
    I'll be doing this swap pretty quick myself, I just traded a 14 bolt for a complete hydroboost setup less the pump :)
  16. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    But will this other pump work?
  17. Russell
    Jun 23, 2000
    7,925
    337
    I'd imagine it will fit, but if it doesn't, it should be easy enough to swap the pump's brackets around with your existing one.
