hydro boost Q's
Discussion in 'The Garage' started by jones, Mar 13, 2007.
  1. jones
    jones 1/2 ton status
    May 17, 2004
    379
    IONIA,MI USA
    What's it look like? How do I know if I've got it?
    It's in an '85 dually w/ hydr 465 (2wd)
    I'm possibly getting the cab and two front clips and hood for trazer build.It doesn't have the booster behind the master cylinder like my '84 has.
    Does anyone have pics of the firewall area of hydroboost equipped trucks? Thanks
  2. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    look for lines connecting your power steering pump to your master cylinder area
  3. 74poj
    74poj Registered Member
    Apr 12, 2005
    46
    Montana
    here's a pic of the hydroboost on my 84 K30. not the best seeings it's the middle of the night and all.:D
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    All 1 tons and all diesels had hydro boost so chances are so do you. By your description with no booster you have a HB booster rather than vacuum.
    I dont seem to have any pics of my setup.
    Ira
  5. jones
    May 17, 2004
    379
    IONIA,MI USA
    That helps. It's definately got hydro boost.:D
    Now here's some more questions. The hard line in the pic,off the master cylinder,closest to the firewall.Is that parts store replaceable?Mine has been cut off. What does that line go to? The truck hasn't been dropped off yet so it's not here for me to look at. it has a hydro 465 in it,also,which will be replaced w/ a 350/205.What do I do with the slave cylinder?Just pull it off or what.I'm new to the hydro stuff if you can't tell.By the way,I did search but couldn't find the info I needed.
    Here's the run-down on my new project.
    '85 c30,hydro 465, wiring harness has ben cut,set up for dual batteries(factory option?has battery trays on each fender)I'll be using the cab/front clip only for trazer build,will most likely sell the trans. or keep it for future use with a divorced Dodge 205.I haven't decided. Is there any benefits to keeping the power steering set-up that is currently on it?
    That's all the questions I have for now. Thanks guys!
  6. sandawgk5
    Oct 28, 2003
    6,881
    You can pick up any of the lines at the parts house.
    Ira
  7. dremu
    Feb 27, 2000
    15,963
    454
    East of San Francisco
    If you're going to use the hydroboost setup, you'll want the power steering pump -- it has the extra fittings. The 2WD steering box is also useful for crossover steering, and/or if yours has the other style fittings for the hydroboost conversion.
    -- A
  8. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    What extra fittings?
  9. dremu
    Feb 27, 2000
    15,963
    454
    Two return lines on the reservoir.
    Oh oh oh oh ... to the OP ... get the brake pedal off the donor truck, as they're different than a vacuum boost pedal. Really.
    -- A
  10. jones
    May 17, 2004
    379
    IONIA,MI USA
    You lost me,Bro. If it's already got hydroboost,what conversion would I be doing.
    I need a couple more pics,too,if someone can get them.1)as you're facing hydro MC,on the left(pass.side)is a cylinder looking thing.What is that? 2)Right next to the MC on the right(D side)there is something missing.two bolts holding it to the firewall.What is that?
  11. dremu
    Feb 27, 2000
    15,963
    454
    I thought you were taking the hydroboost off that truck to put onto another -- no?
    -- A
  12. sandawgk5
    Oct 28, 2003
    6,881
    The cylinder thing is an accumulator. It allows you to have assisted braking for 2 stops if the engine is not running. As for the other part I am having trouble picturing what you are saying.
    Ira
  13. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I have a setup that has a T in the return line down by the box.
    Chris
  14. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    It dark down there but you can see my T in front of the pump pulley down on the frame.The return comes out of the box and right into it :D
  15. sandawgk5
    Oct 28, 2003
    6,881
    I had a T when I first but I had too much backpressure on the return line and it was causing my brakes to activate and drag.
    Ira
  16. jones
    May 17, 2004
    379
    IONIA,MI USA
    No. The whole cab/front clip,hydro assembly will be coming off the c30 frame and transferred to the blazer frame. So everything(basically)is already there.
    The part that has been removed is to the right of the MC,between it(MC)and the wiring harness held with two bolts.
    Thanks for your patience,guys.I wish I was equipped to post pic.However I'm not that technologically advanced:o
  17. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Clutch slave :thinking:
  18. sandawgk5
    Oct 28, 2003
    6,881
    Sounds to me like the Master cylinder for the Hydro Clutch. The slave is on the tranny:D .
    Ira
  19. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Oh yea,duh :doah:
    That would be the master wouldnt it :D
