Hydro-Boost questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Pure Insanity, Dec 4, 2001.
  1. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    I am looking for a Hydro-Boost set up for my Blazer. I have 1 place checking to see if they have one, he said the pump is a higher pressure, is this true? I thot the only difference was the return line on the reservouir. I read just last week that the pumps were the same except for the return line so I may not get it, and just T it into the P/S return. Provided he has one. If this is true I will just tell where ever I get it that I am gonna get a new pump.
    The 2nd place said that the yrs matter. I didnt think that the yr would make a difference. They didnt have one anyhow, for the yr I asked for.(86) The 2nd guy was a total jerk anyhow. This used to be my favorite junk yard till they hired this guy. He is a rude obnoxious know it all. I used to deal straight w/ the owner, and could haggle w/ him, and he let me in the yard to look around, w/out having a specific part I was looking for. How many times have you been wandering around a junk yard and stumbled across something?
    Anyway! I did get a lead from the 3rd place, to a yard that has mostly trucks. What should I expect to pay for a Hydro and the lines?
    One last question, does the Hydro hold a reserve like vacuum does after the eng. is off? I would assume it does, but I would like to know for sure.
    Thanx!
    If ya can't stop.......Smile as you go under! [​IMG]
    PIC of mine from flblazers site<a target="_blank" href=http://www.flblazer.alloffroad.com/photo3.html>
    GO</a>
  2. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Not 100% sure of this but I don't think it holds a long reserve. My brother in laws Chevy with Hydro assist brakes are funky when the engine isn't running and it seems like no reserve (don't ask me how I know [​IMG]). As far as years being different, it may be the same difference as regular boxes and pumps. There was a switch between flare and o-ring seals for the lines, and someone like Boss should be able to tell you what years had which (probably the same for hydro assist), which is probably the reason he said years matter. Same token though, if you get the donor pump AND box from the same vehicle it shouldn't matter, they will be both one or the other. Hope this helps.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot> click here </a>
  3. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    Here are some articals I found. Pretty good info.
    http://www.monsterslayer.com/jeep/HydroBoost.htm
    <a target="_blank" href=http://www.members.tripod.com/surfmac/21.html>http://www.members.tripod.com/surfmac/21.html</a>
    See Ya,
    Keith
    <font color=green>Born to Drive My K5</font color=green>
    <a target="_blank" href=http://coloradok5.com/gallery/californiak5>CaliforniaK5's Pictures</a>
  4. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Thanx for the info guys! I have gotten approval from the "Bank of Wife" to go for it if I want to. So maybe tommorow Ill try to pick one up. If I can find one that is.
    GO</a>
  5. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Do a search for more posts. For ease of assembly get the
    whole works from an early 80's up to around 88 half ton
    3/4 or one ton prefer. 6.2 blazer or sub. Get brake pedal
    push rod and maybe brake pedal too. Gas and diesel not the
    same.-Jim
    88 5.7 5in lift 35"procomp at's
    700-208-456-3in exh w/flowlowder 10 bolts & some ORD stuff
  6. californiak5
    Oct 25, 2000
    820
    Hey Steve, here is one more link. <a target="_blank" href=http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=194988&amp;part=1>Hydroboost</a> It was when I was asking about it and 502Burban had some good info for me. And no, I have not done it yet but I do have all the stuff. Now I just need time. [​IMG]
    See Ya,
    Keith
  7. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Thanx Keith. I found that one when I did a search on this earlier today, and saved it for reference. Definatly a good one.
    I just got off the phone and found one locally. [​IMG] The guy is a bit leary of it tho, he said it has been sitting for a long time at his yard. He did not know if it was still a sealed system or not, so I will have to drive up there tomorrow. (maybe Ill drag my butt up there today) LOL!
    Cross your fingers for me! May even get it cheap since I will be taking a chance on it after sitting so long.
    GO</a>
  8. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    One note, there is a difference between boosters (the amount of assist) from Blazers and K30s. Don't know about the 3/4 tons. Found this out the hard way when someone installed a booster for a M1008 CUCV on a M1009, made the brakes REAL touchy 'til we figured out what the problem was.
    Real trucks don't have spark plugs!
